Page 3 of 21 FirstFirst 1234513 ... LastLast
Results 31 to 45 of 314
Thread: Vu+ Duo 2
  1. #31
    Am uitat sa precizez ca acea telecomanda mica/Ultimo, are tastatura pe partea cealalta. Am testat tastatura si merge OK.
    Pentru cei care au cumva de gand sa lege o tastatura externa la receiver, pot recomanda aceasta telecomanda.
    Numai bine
  2. #32
    Default Duo2 CFE bootloader update
    This update is needed to use the plugin "Wake on Lan" that will be available in the next Black Hole 2.0.5 version for Duo2.
    Instructions:
    1. Unzip the Duo2_CFE_V2.zip to USB stick.(cfe_cfe_auto.bin, cfe_cfe_auto.md5sum and cfe_cfe_auto.model should be at /vuplus/duo2 folder)
    2. Insert USB stick into the USB port of Duo2 and turn the power on.
    3. Press the front power button when Update message is shown.
    5. It takes just a few seconds to update.
    5. If Duo2 displays the message "Finished..reboot", remove the USB stick and restart the box.
    5. To update image later, you should delete the all cfe_cfe_auto.* at /vuplus/duo2 in USB stick once CFE update is finished.
    File:
    https://www.dropbox.com/s/ds4nspxngel37wp/Duo2_CFE_V2.zip
  4. #34
    SUBpedia Expert
    P'aci, p'acolo...
    Quote Originally Posted by WebMan View Post
    telecomanda îmi va fi trimisă când va fi disponibilă...
    Astăzi am primit telecomanda originală, este exact asta:
  5. #35
    US of Europe
    pacat doar ca e . . . prea mica si trebuie sa te cam chiorasti la ea seara pe-ntuneric.
  6. #36
    Default Black Hole Vu+ Duo2 2.0.5 galaxy
    Black Hole 2.0.5 galaxy
    "The Black Hole is expanding in our galaxy.
    We need more space..."
    Starting from this version, the Black Hole image will fully support an internal hdd larger than 2 TB.
    The new initialise function will partition your hdd with optimal alignment and will format it in the linux ext4 filesystem, which will give the best performance.
    Warning: Duo2 requires a Cfe upgrade to V2 before you flash this image.
    Main changes:
    • New Support hdd larger than 2TB
    • New Subtitle customisation
      • Ttx subtitle font size
      • subtitle delay when timing lags
      • subtitle delay when timing is bad
      • yellow Dvb subtitles
      • centered Dvb subtitles
      • Dvb subtitles black transparency
    • New support for coldboot "Wake on Lan" (Duo2)
    • New firmware upgrade option for Vfd controller and Front Processor (Duo2)
    • New hotkey for Subtitle window: (2x Yellow button)
    Vu+ Drivers updates (duo2):
    • Fix WOL problem
    • Add proc entry for WOL
    • Fix loop-through problem when 2 dual tuners are installed
    • Improve VFD controller update(VFD controller update will resolve remote control sensitivity issue)
    • Fix Play/Pause key problem
    • Support FP update
    • Support VFD controller update
    • Fix recording problem
    • Fix no audio in radio channels
    Misc:
    • Add Tools/Alternatives
    • Add WOLSetup (WakeOnLan) plugin (Duo2)
    • Add parted tool to partion and format internal Hdd
    • Switch to parted and ext4 in hdd inizailise function
    • Change module description from RT2870 to RT3070/3370/5370/5372 and fixed module installation in the correct place
    • Add patches for RT3070 ralink driver
    • Fix rt5572 driver
    • Add some devices not yet included into rt5572 supports
    • Add web-manual Duo2
    • [HbbTV] fix rtl auth problem
    • Add fuse-module and fuse-utils for ntfs-3g
    • [Kernel] Solo2 & Duo2: Add Nls modules for other charsets
    • [Kernel] Fix flash_erase option on postinst
    • [Dvbmediasink] Fix switching between aac and other codecs
    • [Gst-plugins-bad] Update SRCREV & patches
    • Add checkvfd package
    • Added new driver mt7610u (802.11a/b/g/n/ac support)
    • Update languages cs, da, fr, sk, sv.
    WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
    The image MUST be installed in flash.
    Black Hole does not support images not installed in flash.
    This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UPnP Server Mediatomb
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    Black Hole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to Pedro_Newbie for Backup script
    Thanks to [email protected] for the file satellites.xml.
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    LICENSE (TERM OF USE)
    BlackHole-2.0.5-vuduo2_usb.zip
    File size:73.1 MB
  7. #37
    Mar 2007
    @Didi : Si, cum esti multumit de noul Duo 2 ? Astept cu nerabdare cateva randuri cu primele tale impresii, teste, comparatii (cu Vu+ Duo, cu DM 7020 HD, ...)
  8. #38
    Quote Originally Posted by rocky7 View Post
    Da, sunt foarte multumit de Duo2, dar asta nu inseamna ca sunt mai putin multumit de vechiul Duo, practic, tot ce face Duo+rama foto, face si Duo2 dar mult mai repede ( folosesc aceleasi imagini, aceleasi configurari, telecomenzile sunt aproape identice...astfel incat sotia mea nici nu a realizat ca are inaca un receptor nou in ograda...deci => armonie in familie )
    In concluzie, putem spune ca este aceeasi masina dar cu alta "motorizare", insa care se va detasa de Duo pe masura dezvoltarii imaginilor.
    Este un receptor care face toti banii
    Eu unul ma feresc sa fac comparatii cu Dreambox pentru a nu crea animozitati, fiecare tip de receptor are partile lui mai mult sau mai putin bune...
  9. #39
    Dec 2012
    Salut,
    Poti recomanda un comerciant mai ieftin? Vreau sa comand si eu si am gasit pe la 495 E +transport din afara.
    Emme Esse 115cm, h-h Stab 120,Vu+ Solo​2, Samsung UE40ES6710, tevii s660 dvb-s2,
  10. #40
    Feb 2011
    Sep 2003
    Nedelea,Prahova
    intreba omul de un comerciant mai ieftin de 495E+transport.pretul de la satmultimedia e 570E.
  12. #42
    Daca esti user pe Vu+ Support Forum vei putea primi 3% rabat la HM-Sat.de. In cazul meu 499€ - 3% = 485€, unde si transportul a fost gratuit, doar DHL a cerut 2€ in plus.
    Bineinteles sa locuiesti in DE, altfel nu stiu cum e cu transportul.
    Numai bine
  13. #43
    Dec 2012
    Am gasit la 540E + transport (30E) cu tuner dublu DVB-S2 si tuner DVB-C/T.
    Cel de la Satmultimedia vine doar cu un tuner single DVB-S2.
    495E este chel.
    http://www.shopping4satellite.com/vu-duo2.html
  14. #44
    Sep 2003
    Nedelea,Prahova
    Quote Originally Posted by perseus View Post
    495E este chel.
    cum poti spune ca e chel la 495E?poti pune 2 tunere single sau cablu/terestru .
  15. #45
    Dec 2012
    Da, ai dreptate! Iluzie vizuala.
