Page 2 of 21 FirstFirst 123412 ... LastLast
Results 16 to 30 of 314
Thread: Vu+ Duo 2
  1. #16
    España Teacher
    May 2010
    La Mancha, España
    Si pe aici se pare ca o sa apara , dar fara pret de moment ! , http://www.incopia2.com/shop/noticias.php
  2. #17
    iphone unlocker Expert
    Costa Tropical(ESPAÑA)
    Nobody is Perfect
    I am Nobody
  3. #18
    Apr 2008
    Salut,
    Dupa ce un prieten a vorbit la Anga cu importatorul pt Germania( Satco) a aflat ca Vuo Duo 2 se va livra undeva la mijlocul lunii iulie.
  4. #19
    US of Europe
    HM Sat VU+® Duo² ab 8.7.2013 lieferbar
    http://www.hm-sat-shop.de/hdd-receiv...00-gb-hdd.html
    ,,*** Time is an illusion ! ***,,
  5. #20
  6. #21
    Dec 2008
    Si aici am vazut : www.eurovux.com .In jurul datei de 17 iulie vor fi pe stock.
  7. #22
    Apr 2008
    In Germania sunt pe stoc..
    Am comandat eu pt un amic si azi il primeste.
  8. #23
    Feb 2011
    Default Black Hole Vu+ Duo2 v. 2.0.4
    Black Hole 2.0.4
    • New: Subtitle Auto Language Support
    • New Skin: MX S Line by Matrix10
    • New: Vfd skin by Ev0 (duo2)
    • Custom updated version of lcd4linux (duo2)
    • TranscodingSetup : add bitrate/framerate support (duo2)
    • Update Hbbtv and opera browser
    • New Vu+ drivers 20130703(duo2)
      - Support transcoding bit/frame rate change(100K< bitrate< 5M, framerate=23976 24000 29970 30000 59940 60000 )- Enable SD video when transcoding
    • New Vu+ drivers 20130621(all):
    - Fix TS Playback problem
    - Fix i2c error handling
    - Turn off LCD at standby by default(duo2)
    - Change default LCD brightness(duo2)
    - Support DVB-T external antennae(duo2)
    • Misc:
    fixed to be used the rc-keyboard at duo2.
    vuplus homepage url changed www2.vuplus.com -> vuplus.com
    remove the uri log when playing the vod
    NetworkWizard : remove confdns for inet static.
    Adjust kernel config (duo2)
    added libcec
    gstreamer_0.10.36.1.bb: fixed "GStreamer-CRITICAL
    opkg: some fixes/changes for handling packet recommends
    busybox: passwd use SHA512 by default
    busybox: mount: don't pass option auto to kernel
    do sync after umountfs
    gst-plugins-good : remove gtk+ on DEPENDS
    make RDEPENDS of package specific
    dbus-1.4.16: fix compile with c++11
    update python-coherence
    update OpenWebIf
    update languages: fr cs fr sv sk
    WARNING: This Image has the latest drivers and CAN NOT be installed in multiboot.
    The image MUST be installed in flash.
    Black Hole does not support images not installed in flash.
    This latest version of the Black Hole series has been entirely rewritten and improved in the code for maximum stability and performance.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature gives the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UPnP Server Mediatomb
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    Black Hole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to Pedro_Newbie for Backup script
    Thanks to [email protected] for the file satellites.xml.
    Thanks to Littlesat and Pli Team for the original autolanguage selection code
    DISCLAIMER
    LICENSE (TERM OF USE)
    BlackHole-2.0.4-vuduo2_usb.zip
    File size:63.5 MB
  10. #25
    @robi22, l-ai butonat ? Ce impresia ai ?
    Ce m-a interesat pe mine cel mai mult, MediaPortal, merge ca ceasu si prin W-Lan. Butonez la el, am pus oscam/client, si deocamdata este in dormitor conectat prin W-Lan integrat. Cand voi avea mai mult timp, voi testa cartele/CS pe el.
    Numai bine
    PS: exista cumva ceva plugin gen MediaPortal cu pagini RO ?
  11. #26
    EXPERT GIGABLUE & IPTV Expert
    Feb 2010
    doar daca le implementezi tu sau vb cu autorii pluginului
    pluginuri ro asemanatoare nu sant...de fapt e ceva romanesc?...ptr ca noi asteptam mai mereu mura in gura....varza sau ce o fi
    GIGABLUE 800HD SE...GIGABLUE
  12. #27
    Apr 2008
    Quote Originally Posted by Bumbu View Post
    Numai bine
    Nu l-am butonat inca.dar o sa primesc unul pt teste.nu fac colectie..si nici dealer nu sunt.
    Dar saptamana asta primesc 2 produse coreene Vuo duo 2 si Iqon 100HD pt teste.
    Solo 2 care il am..merge perfect pt ce am eu nevoie.
  13. #28
    @Bumbu
    Intr-o poza, postata de catre un betatester a unui Duo2, versiune pre-productie, se vede ca este echipat cu 2 telecomenzi.
    Intrebarea mea este daca la intrarea in productia de serie au trecut la o telecomanda dedicata Duo2 sau este tot cu 2.
    Am comandat si eu, dar mai dureaza ceva pana intru in posesie si sunt curios.
  14. #29
    Telecomanda cea mica din poza este telecomanda unui VU+ Ultimo, pe care o am si eu, si care si merge super bine pe VU+ Duo2. Telecomanda "originala" este una ca la celelalte modele mai mici, in negru, cum se vede in poza.
    Ce am primit eu extra, este un "Gutschein/Cupon", unde este o poza cu o telecomanda noua, nemaivazuta de mine la VU+, la care este precizat ca voi putea prin acel COD sa comand acea telecomnda "free" de la ei, dar doar o singura comanda pe 1x COD. Ma gandesc ca voi comanda acea telecomanda.
    Numai bine
  15. #30
    SUBpedia Expert
    P'aci, p'acolo...
    Şi eu tot COD am primit (+ telecomandă la fel ca la Solo2), le-am trimis mail cu codul primit şi mi-ai trimis deja factură la 0 € plată,
    telecomanda îmi va fi trimisă când va fi disponibilă...
There are currently 2 users browsing this thread. (1 members and 1 guests)
