Page 20 of 21 FirstFirst ... 1018192021 LastLast
Results 286 to 300 of 310
Thread: Vu+ Duo 2
  1. #286
    Default OpenBH 0.6 Vu+ Solo4K
    OpenBH 0.6
    Whats New:
    • Completely new image, now much more compact and lightweight than ever before
    • Switched to new Enigma2 base
    • Added BH SpeedUp panel (so you can add or remove some features)
    • Updated to Inadyn-mt
    • Updated OpenMultiboot (now shows image names on front panel display)
    • Updated to Gstreamer 1.9.0 (GIT)
    • Updated to OE3.4 core
    • Updated to Python 2.7.11
    Main Features:
    • MX HQ9W Full Hd skin (1920x1080)
    • Kodi and Youtube Tv (for those models that support it)
    • Chromium OS or Opera (for those models that support it)
    • HbbTv (for those models that support it)
    • OpenMultiboot (all Vu+ models supported)
    • OE-A Plugins
    Black Hole:
    • Blue panel
    • Green Panel
    • Extra Settings
    • Addons panel
    • SpeedUp panel
    • OpenSSL patched for backwards compatibility with some plugins
    • Compatible with OE-A and PLi plugins and Skins
    What is OpenBH ?
    It is an exciting project from the same team that produce the Black Hole images.
    This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
    This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support..
    As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
    Do I have to upgrade to this new OpenBH image ?
    No you don't have to upgrade to the new OpenBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
    What about the Black Hole and Black Hole Prism Images ?
    For those of you worried about the standard Black Hole and Prismcube image, please dont worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new OpenBH image is an additional project and we are fully committed to all images.
    Where can I find the OpenBH git ?
    The OpenBH git is located here: https://github.com/BlackHole
    DISCLAIMER
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
    openbh-0.6-vusolo4k-20160627_usb_release_dfa51a6.zip
    File size:67.6 MB
  2. #287
    Va salut. Am un vu+duo2 cu OBH 0.6 si pluginul aspect ratio switch nu functioneaza deloc, intra in eroare. Am reinstalat img-ul dar acelasi rezultat, la fel cand am sters pluginul si am reinstalat din nou. Mai are cineva problema asta?
  3. #288
    May 2014
    undeva pe pamant
    Astazi sa marit gama VU+ la mine. Pe langa Vu+uno, zero, solose, folosesc si duo2. Prima impresie ? UN OZN. Sa ma apuc de treaba.
  4. #289
    Corabia
    Am un Vu+ Duo 2 cu 2 tunere.Intrebare: cum si ce setez sa activez al doilea tuner?
    Rapidist pur singe...
  5. #290
    SUBpedia Expert
    P'aci, p'acolo...
    Băi, ţi-am zis la telefon....
    Bagi srma n tuner II, l setezi cu toate lenebeile tale, apoi la setare la tuner I l pui n cascadă de la tuner II
  6. #291
    Corabia
    La 60 de ani omul mai si uita...
    Poate imi scri explicit ce trebuie facut la configurare tuner.Am imagine PLI.
  7. #292
    Default Black Hole 3.0.3 Kodi Vu+ Duo2
    Merry Christmas from the Black Hole Team
    What is new ?
    - Add Support for Uno4K and Ultimo4K
    - Update default skin MX HQ10 for extra tuners
    - Update skin api
    - Update OpenMultiboot
    INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to plnick for help obtaining missing Ultimo4K files.
    Thanks to Pedro_Newbie for Backup script.
    Thanks to [email protected] for the file satellites.xml.
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    LICENSE (TERM OF USE)
    BlackHole-3.0.3-vuduo2_usb_release_20161224_d3f1586.zip
    File size:147.4 MB
  8. #293
    Default Black Hole 3.0.3.D Kodi Vu+ Duo2
    What is new ?
    - Update default skin MX HQ10 to fix font issue's with Ultimo4K
    - Update drivers (solo4k, uno4k, ultimo4k)
    - Update libvugles2
    - Update Satellites.xml, Cables.xml and Terrestrial.xml
    - Update Danish, French, Italian, Lithuanian, Norwegian, Polish, Portuguese and Spanish translations
    - Update epgcache for MHW2
    - Update OpenWebif
    Addons
    Infobar / OSD
    Analog Clock Gui
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    UPnP Client Djmount
    Pcsc Panel
    Tuner Server
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    DISCLAIMER
    BlackHole-3.0.3-vuduo2_usb_release_20170127_371b7f5.zip
    File size:149.5 MB
  9. #294
    Default OpenBH 1.0 Vu+ Duo2
    OpenBH 1.0
    Whats New:
    • Updated to OE4.0 core
    • Updated to Python 2.7.12
    • Updated to Gstreamer 1.11.2 (GIT)
    • Automatic backup before online update
    • Option to view changes before online updating
    Main Features:
    • MX Titanium_C Full Hd skin (1920x1080)
    • Kodi 17.1 (for those models that support it)
    • Fallback - Fallback tuner settings moved to Service searching menu into its own menu
    • Fallback - Remote bouquets copier (Channel Importer). For receivers used as clients, copies and loads the channel list from the server box.
    • Fallback - ability for client to not write EPG data back to server box. Means epg.dat can be shared over a network mount without fear of corruption.
    • Various OE-A Core updates.
    • Updated Service Info screen
    • Updated Streaming Clients screen (skin dependant)
    What is OpenBH ?
    DISCLAIMER
    openbh-1.0.001.release-vuduo2_usb_release_08eb6e0.zip
    File size:77.1 MB
  10. #295
    Default Black Hole 3.0.4 Vu+ Duo2
    Black Hole 3.0.4
    What is new ?
    - Add Quad Picture in Picture support (Ultimo4K, Uno4K, Solo4K)
    - Update CrossEPG to support new Rytec xz compression XMLTV listings
    - Update CrossEPG to include latest Rytec Providers
    - Update OpenWebif to fix Grab and WebTV
    - Update Drivers (Ultimo4K, Uno4K, Solo4K, Duo2, SoloSE, Solo2, Zero)
    - Fix FCC to work with usb tuners (Ultimo4K, Uno4K, Solo4K)
    - Update Bluetooth Support (Ultimo4K, Uno4K, Solo4K)
    - Update default skin to support Quad PiP
    - Update Italian translations
    Addons
    Infobar / OSD
    Analog Clock Gui
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    UPnP Client Djmount
    Pcsc Panel
    Tuner Server
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    DISCLAIMER
    BlackHole-3.0.4-vuduo2_usb_release_20170909_0782c55.zip
    File size:149.8 MB
  11. #296
    Default OpenBH 4.1 Vu+ Duo2
    OpenBH 4.1
    Whats New:
    • Updated to OE4.1 core
    • Updated to Python 2.7.13
    • Updated to Gstreamer 1.13.0
    • Glibc 2.2.5
    • GCC bug fixes
    • openSSL Security fixes
    • Basis for new 64 bit environment Support for multi libs 32/64 Bit
    • Stability updates
    • Based on OE-Core Morty
    • MX BlackShaddow_P Full Hd skin (1920x1080)
    • Kodi 17.6 (for those models that support it)
    DISCLAIMER
    openbh-4.1.001.release-vuduo2_usb_release_4f40859.zip
    File size:81.2 MB
  12. #297
    May 2014
    undeva pe pamant
    uitati-va cum putem fi pacaliti cu un soft . vu+duo2 -caracteristici : Meniu - informatii .
    Vu+duo2 are ......
    Processor Broadcom 7424
    Processor type 1.3 GHz (3K + DMIPS)
    Si eram ferm hotarat ca pana la 31.12.1017 sa cumpar un vu+ultimo 4K.
  13. #298
    nuca de cocos Mentor
    Oct 2008
    SV.Romania
    .... se vede 3K mai pui 1 si ai 4K, nu vad unde e pacaleala.
    OCTAGON SF4008 4K the best receiver enigma2 , VU+ultimo 4K,Vu+solo2,Xtrend9200 , Dream500 S , Sky Star HD2 , Antena 1.8 Circulara Al motorizata, Antena 1.6 Circulara Al Fixa Lnb Twin , 2 Antene 1.2 Ofset Fe Lnb Quad , Antena 1.0 Ofset Fe Lnb Quad , Focus Sat Full HD , FreeSat TVR HD
  14. #299
    May 2014
    undeva pe pamant
    vu+duo2 care are procesor Broadcom 7424 de 1, 3 Ghz dual cores . Dupa instalarea imaginii black hole 3.04 la info- despre , arata ca are procesor ARMv7 de 1,5 Ghz dual cores. interesant , nu ?
  15. #300
    Oct 2008
    SV.Romania
    imaginile lasa de dorit in ultimul timp, cind am luat octagon nu arata corect 1gb memorie la toate imaginile instalate, doar 256Mb, la fel si cu Vu+ultimo4k din 3Gb arata 1Gb .....nici acum nu arata corect toate, zici ca sunt facute la norma.
    asa ca nu te mai uita la ce zice info despre receptor, doar stii ce are in dotare.
