Thread: Help Shlcrypt!
    May 2004
    Default Help Shlcrypt!
    Am mai multe nelamuriri in legatura cu SHLCRYPT:
    1. merge si cu Prog DVB si cu MyTh?
    2. merge cu Yanksee? Dar cu S2emu1.6?
    3. in care subdirector se incarca?
    "Search" in topic nu m-a lamurit. Multumesc pentru ajutor
    May 2004
    Pentru ce ai nevoie de el? S2emu decodeaza direct, fara dll-ul respectiv. Daca vrei doar dll-ul atunci trebuie ca aplicatia sa transmita pachete (la plugin) de 184 de octeti. Altdvb stie acest lucru, progdvb NU stia (cand l-am abandonat eu, de vre-o doua luni - poate intre timp are si asa ceva)
    May 2004
    Default Re: Help Shlcrypt!
    Quote Originally Posted by tabaluga
    si SHLCrypt merge cu ProgDVB & MyTheatre
    Yankse & S2Emu both merge cu ProgDVB,MyTheate but one of them should be disable, use one at a time
    cu ProgDVB copy Yankse and/or S2Emu files on C:\ProgDVB folder and for MyTh copy them in mdplugin/plugin or C:\Progra..\MyTheatre folder, one of them should work
    May 2004
    Multumesc pentru raspunsuri! Stiam amanuntele legate de Yanksee si S2emu (nu se folosesc impreuna, etc.) Nu insa stiam daca SHL se poate folosi impreuna cu unul din ele. Din raspunsuri am dedus ca SHL este decodor de sine statator. L-am instalat in MyTh si merge!
    Thanks!
  1. shlcrypt nemic?
    By horatiu74 in forum Placi DVB
    Last Post: 24th February 2005, 13:44
  2. shlcrypt?
    Last Post: 3rd September 2004, 09:10
  3. Replies: 15
    Last Post: 24th June 2004, 07:02
  4. shlcrypt
    By xamu in forum Placi DVB
    Last Post: 20th June 2004, 17:58
  5. Shlcrypt
    Last Post: 16th June 2004, 06:52
