Page 12 of 15 FirstFirst ... 21011121314 ... LastLast
Results 166 to 180 of 224
Thread: Vu+ General
  1. #166
    Default Black Hole 3.0.2.H Online Update
    There is a new online update available to update 3.0.2.H
    This is available as an online update from 3.0.2 (A,B,C,D,E,F or G)
    Full flash update files also available.
    *** Please note that Fast Channel Change support is experimental, so any bugs that you find, please report, but do not demand fixes, as we will need to wait for Vu+ to fix any issue's ***
    - Implement Menu Ordering
    - Support for new Matrix10 Skins
  2. #167
    Oct 2014
    There is a new online update available to update 3.0.2.I
    This is available as an online update from 3.0.2 (A,B,C,D,E,F,G or H)
    This is a minor update, and is only available via online update
    - Restore original menu layout for older skins
  3. #168
    Oct 2014
    There is a new online update available to update 3.0.2.J
    This is available as an online update from 3.0.2 (A,B,C,D,E,F,G,H or I)
    - Update drivers (Solo4K )
    - Fix FCC problem (Solo4K)
    - Add new FBC frontend proc interface (Solo4K)
  4. #169
    Oct 2014
    New online Update 3.0.2.K
    [Videomode] Updated
    - Support YPbPr(444,422,420) for HDMI colorspace
    - Support HDMI colordepth
    - Update driver(solo4k)
    - Fix FCC problem(no video when returning from media playback)
    - Add proc entry for more options in hdmi color space and depth.
    Ultimo 4k oficial
  5. #170
    Default Black Hole 3.0.3.A Kodi
    What is new ?
    - Update default skin MX HQ10 to fix some plugin issues
    - Update skin api to fix some plugin issues
    - Update Unicable and Unicable II LNB support
  6. #171
    Default Black Hole 3.0.3.B Kodi
    What is new ?
  7. #172
    Default Black Hole 3.0.3.C Kodi Online Update
    The latest Black Hole image is 3.0.3.C
    What is new ?
    - update drivers(duo2, solo2, solose, zero)
    - Fix refresh rate
    - Fix FF in media playback
    - Add more video codecs
    - Add videomode_24hz proc entry(E2 update will follow)
    - Fix misc.
    This is only available as an online update from 3.0.3, 3.0.3.A or 3.0.3.B
  8. #173
    Default Black Hole 3.0.3.D Kodi Online Update
    The latest Black Hole image is 3.0.3.D
    What is new ?
    - Update default skin MX HQ10 to fix font issue's with Ultimo4K
    - Update drivers (solo4k, uno4k, ultimo4k)
    - Update libvugles2
    - Update Satellites.xml, Cables.xml and Terrestrial.xml
    - Update Danish, French, Italian, Lithuanian, Norwegian, Polish, Portuguese and Spanish translations
    - Update epgcache for MHW2
    - Update OpenWebif
    This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B or 3.0.3.C or as a fresh install
  9. #174
    Default Black Hole 3.0.3.E Kodi Online Update
    The latest Black Hole image is 3.0.3.E
    What is new ?
    - Fixed a bug when playing m3u-stream (iptv)
    - Update Norwegian translations
    This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C or 3.0.3.D or as a fresh install
  10. #175
    Default Black Hole 3.0.3.G Kodi Online Update
    The latest Black Hole image is 3.0.3.G
    What is new ?
    - update drivers(uno4k, ultimo4k)
    - Fix HDMI out problem(idle mode & wake up)
    - Fix FBC DVB-C problem
    - Fix pixelation problem(ultimo4k)
    - Support 4K transcoding in idle mode
    - Fix problem when there are 2 transcodings at the same time.(ultimo4k)
    - Change recording resolution of HDMI-IN to fixed 720p (ultimo4k)
    - update FCC plugin, Fix PIP issue due to FCC
    - update FCC plugin, FCC is available only for dvb services (service type == 1)
    - update autolanguage plugin to include: Ukrainian and Visual impaired commentary
    - update Russian translations
    - update usbtunerhelper to help with devices with unknown manufacturer
    This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E or 3.0.3.F or as a fresh install
    PLEASE NOTE, THAT ALTHOUGH YOU CAN ONLINE UPDATE TO 3.0.3.G THE REVISION NUMBER MAY NOT UPDATE, BUT THE UPDATES WILL HAVE BEEN APPLIED STILL.
  11. #176
    Oct 2014
    The latest Black Hole image is 3.0.3.H
    What is new ?
    - [gstreamer1.0-plugin-subsink] fix SRC_URI
    - Support VUPLUS BLE RCU.
    - update vuplus-bluetooth-util & bluetoothsetup.
    - add new plugin wit.ai speech to text.
    - [RcInput] handle key tape. (for VUPLUS BLE RCU)- update chromiumos to support bt-rcu.
    - [webkit-hbbtv] update hbbtv.
    - [linux-vuplus] enable usb serial device drivers for ARM receivers.
    This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F or 3.0.3.G or as a fresh install
    1W-13E-16E-19.2E
    Offset Triax (Alu.) 1.00
    Offset Multifeed Emme Esse (Alu.) 1.15
    VU+ Ultimo 4K/VU+ Solo SE V2/ VU+ Zero/ GM Triplex /Amiko Spiel/
    Digi Cablu /Focussat /SRTV
  12. #177
    Oct 2014
    Un nou tip de remote BT/IR listat la 49euro
    1W-13E-16E-19.2E
  13. #178
    Default Black Hole 3.0.3.I Kodi Online Update
    The latest Black Hole image is 3.0.3.I
    What is new ?
    - Update Kodi 16.1 to 17.0 for ARM boxes only (Solo4K, Uno4K, Ultimo4K)
    This is available as an online update from 3.0.3, 3.0.3.A , 3.0.3.B, 3.0.3.C, 3.0.3.D, 3.0.3.E, 3.0.3.F, 3.0.3.G, or 3.0.3.H
  14. #179
    Default Vu+ Zero 4K and Uno 4K SE Announced at Anga 2017
  15. #180
    - - - Updated - - -
