Results 1 to 6 of 6
    Default Problem with Humax IR ACE II
    IR ACE II having a problem, after about an hour system get stuck then I have to switch off power and on to get back to normal.
    I did reset the unit to factory default settings and it did not sort the problem..
    Unit loader status:
    IRD Ser # 13T05096204337
    IRD : 15.12.6
    CA Module: Softcell Ver. 2.25
    IRD SW: MFSIR 1.00.09
    APPL SW: APMW – MFSIR.1.00.09
    DRIVER SW: DD-MFSIR.1.00.09
    Bin 2 IR Ver: 3.19
    Bin 2 IRD Ser. 0001
    Siign DAte: 21/6/05
    D Load date: 01/01/99
    Sign
    Please help me how to solve this problem
    Aug 2004
    M east
    I have got the same problem more than 5 receivers, when the prize going very low the Hard ware also not good. May be the software. But not availabe now if anyone have aidea plz inform here.
    Tech
    Try to reduce the number of channels (delete all unused channels and satellites) and the receiver will move faster and will not stuck anymore.
    Aug 2004
    M east
    My friend Kroky its only using nilesat channels, some boudy only watchin JSC sports channels.Til the same problem. You r my best friend when my 5400z problem sloved beafore. Thank you a long time U R not on the RDI forum is int it?.
    Tech
    Hi,
    I only connected the receiver to one sat (Nile sat), which mean the happens not because of heavy load on the receiver but pretty sure of the SoftWare.
    I will be very greatful if some body can help with newer software.
    Your help and support is appreciated.
    Aug 2004
    M east
    Today 2 customers came and repeted the same problem so please any suggession.
    Tech
  1. Problem with Humax?
    By noori in forum RDI - English
    Last Post: 15th September 2006, 01:39
  2. HUMAX KEY PROBLEM
    By nesfin in forum RDI - English
    Last Post: 30th May 2006, 21:02
  3. Humax 5400 problem
    Last Post: 12th May 2006, 00:12
  4. Humax Problem
    By s_j_20 in forum RDI - English
    Last Post: 19th January 2006, 16:34
  5. HUMAX F1-CI HUGE PROBLEM-PLEASE HELP!!!!!!!
    By zzzzzz in forum RDI - English
    Last Post: 2nd January 2006, 15:23
