As the same as other tablet, users can use iPad 3 to sharing, playing and business. You can have a lot of choice to access the internet, such as WiFi, 3G or 4G. We all know that iPad 3 will provide 4G via Verizon’s Long Term Evolution (LTE) network. 4G network capability will provide the iPad 3 with several benefits. But before that you should choice a 4g LTE router for your iPad 3, Sierra 754S LTE Mobile Hotspot will be your best choice. It is the latest 4g LTE router developed by Sierra Wireless and supports download speeds of up to 100Mbps and upload speeds up to 50 Mbps.
The Sierra 754S LTE Mobile Hotspot is the fastest Mi-Fi device available. The 4g LTE router comes with a rechargeable 1800mAh battery so you can stay connected on the go. It has LCD screen that displays data such as Provides battery, data usage and signal strength feedback for simple use. Also support an external antenna (antenna sold separately). The frequency bands supported is as below: GSM/GPRS/EDGE: 850/900/1800/1900; UMTS/HSPA+: 850/1900/2100; LTE: 700/AWS.
Using a 4g LTE router, an iPad 3 will be able to provide a download speed of 100 Mbps and faster. The 4g LTE router is able to provide faster download speeds because it offers a wider bandwidth, or a broader range of frequencies over which data can travel. This new LTE hotspot can let the users access the internet with high speed. From the access speed and stable signal, you can see that using a Sierra 754S LTE Mobile Hotspot is the best partner for your iPad.
Using a 3G wireless router, an iPad 3 can provide a download speed, or data transfer rate, of 3 megabits per second (Mbps). In comparison, using a 4g LTE router, the iPad 3 will be able to provide a download speed of 100 Mbps and faster. With the speed of 100 Mbps, online games will be more enjoyable. Provide a stable signal for your iPad 3 is another reason for you to choice Sierra 754S LTE Mobile Hotspot, which means that you can use the 4g LTE router on a train or car without the worry that you will slip off or lose connection to the Internet
Currently this 4g LTE router is the fastest mobile hotspot router on modem3g online store, buy it and experience 4G LTE speeds on your iPad 3. Just turn on the device and connect to your iPad 3 and enjoy it.
