Results 1 to 6 of 6
    Default kabayan
    Kabayan, try to check your satdish or upgrade your reciever,by the way what brand is your receiver? good luck!
    some loving neighbour must have installed something in front of your dish, blocking the signal path. check your cables, lnb and dish alignment as there has been no freqs change on the channels you mentioned.
    middle-earth
    other option:
    you have to fix again your dish,for re-align
    or somebody's playing your dish when your not around
    ..if you don't know how to align,go to the nearest dish installer
    to work this thing.
    peace.
    Iraq
    Default Need Help - Mga Kabayan
    Before i was relocated to another place (oct'05) my receiver (FTA china made) can catch Nilesate and Hotbird. I can watch MBC 2 & 4 on Nilesat and OneTV & CNN on Hotbird. When i came back (Nov'05), its all gone and can only catch few channels on Hotbird, Nilesat is totally gone, no signal. I tried to re-program and install but still no luck at all.
    Since im not good on this field, i'll appreciate any help on how i can bring back those channels again. I don't know what went wrong. Pls advise...
    Ontario, Canada
    kalas,
    check your keys, key codes change from time to time or visit the lyngsat for info about Nilesat...
    Quote Originally Posted by eaglenest
    kalas,
    I don't think it's the key or code that has got the problem as these English channels e.g. MBC2, MBC4 and One TV in NIlesat are FTA.
  1. My SR-150d is dead!!! KABAYAN, please help!
    By bRuTuSq in forum RDI - English
    Last Post: 5th October 2005, 21:38
