Results 1 to 13 of 13
    Jan 2012
    Default Solution to Asisat3S C-band and WiMAX interference
    Hi Guys,,
    I am facing the Asisat3S C-band and WiMAX interference problem.... All V channels are coming fine (Geo news goes crazy sometimes!) while H channels are coming, going and there is no stable signal. Anyhow, the STB was able to tune H-polarity channels.. but it shows "No signal" message through-out.
    I am using 40K single-cable solution LNBF. C-band suffers severely here from WiMAX operator's tower. I am wondering if LNB skew angle is creating a problem... If it is so, then why am i receiving V channels or H probe can still be mis-aligned
    Moreover,I have already moved dish to a place just infront of a wall as getting signal elsewhere is impossible.
    My STB is configured with 5750/5150 Mhz. Does the order of these freqs makes any difference
    Please tell me any other ways of coming out of this probelm....
    Thanks a lot for reading... Now reply...
    Jed, KSA
    Try entering frequency by minusing 600 from them e.g. 4140 freq make it 3540. Check and see.
    Jan 2012
    Quote Originally Posted by afridij View Post
    I think its required when u set 5750/5750 as your LNB freqs in STB.... since i have kept them as 5750/5150..... it does the minusing......
    Africa-Kenya-Nbi
    Quote Originally Posted by tony_starks View Post
    Try using the Eurostar ES-21 plus LNB
    it should be of help to you.
    Jul 2007
    There is some thing wrong with the asiasat from last few days. i m sure every thing will be ok in few days. i m facing also NO SIGNAL problem
    Jan 2012
    Quote Originally Posted by highsignal View Post
    Yes you are right as my Geo news is disturbed too nowadays and it was fine before. But as far as H polarity channels are concerned, i am not able to watch them since I installed the dish. As i told before, I have got them tuned into STB but the signal is so rapidly fluctuating that its hardly viewable. Any advice on protecting the LNB from interference will be appreciable?
    I have seen people discussing about placing a metal sheet, grounding the dish or so? Any confirmed ideas?
    SATELLITE GURU Expert
    What you need are microwave filters and Norsat LNB's and a patriot or other mount
    http://www.norsat.com/wimax-interference-solutions/blog
    Africa-Kenya-Nbi
    Quote Originally Posted by irdeto2engineer View Post
    Hi IR2E.
    thanks for the info, please as usual provide some pictures,
    as I had seen some before on this forum.
    Best regards
    Maybe solar flares from the sun. But AS3 working fine on all freqs for me with a 1.8m solid dish.
    http://www.bbc.co.uk/news/science-environment-16701407
    Jan 2012
    The latest update is, I am back to my stable position. I am able to view all V channels (Geo, PTV,etc) with little or no disturbances. But H channels are not showing up completely, "No signal" comes up so frequently. Any pictures on placing metal sheet etc?
    Jun 2005
    Australia
    Try this
    Uploaded with ImageShack.us
    Jan 2012
    Quote Originally Posted by weirdo View Post
    Try this
    Thanks Weirdo, Excellent job! but dont u think its kind of a proper metal work,,, I was wondering if there is some home-made solution available?
    Can i just put metal sheets around the dish? I have wooden doors available with me, can i place them around it, will wood attenuate WiMAX signal to a certain extent?
    Jun 2005
    Australia
    No idea tony, just try it
