Attached Files:Black Hole 3.0.3.D- Update default skin MX HQ10 to fix font issue's with Ultimo4K
What is new ?
- Update drivers (solo4k, uno4k, ultimo4k)
- Update libvugles2
- Update Satellites.xml, Cables.xml and Terrestrial.xml
- Update Danish, French, Italian, Lithuanian, Norwegian, Polish, Portuguese and Spanish translations
- Update epgcache for MHW2
- Update OpenWebif
INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
- Integrated OpenEpg
- Rytec dedicated epg.dat
- New system epg.dat outside.
This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
Download EPG from any channel
Yellow button = Audio menu
Addons
Infobar / OSD
Analog Clock Gui
Channel orbital location
Signal SNR, BER
Infobar picons
Blue Panel
Extra Settings
Black Hole Speed Up
Devices Manager
Usb Format Wizard
Telnet Panel ( Telnet Panel)
FTP Panel ( FTP Panel)
UPnP Client Djmount
UpnP Server Minidlna
Pcsc Panel
Tuner Server
Network Browse & Mountpoints
Info Panel
3 - About (info)
Memory (Memory)
Space (capacity)
CPU (processor)
Process (process)
EPG Panel
Green Panel
Addons (added)
Online Feeds Settings update
Red Panel
BlackHole
Avalon
Chaos
Ghost
Credits
Thanks to plnick for help obtaining missing Ultimo4K files.
Thanks to Pedro_Newbie for Backup script.
Thanks to [email protected] for the file satellites.xml.
Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
DISCLAIMER
LICENSE (TERM OF USE)
BlackHole-3.0.3-vuultimo_usb_release_20170127_371b7f5.zip
File size:91 MB
