    Nov 2005
    North Waziristan,MirAli,Pakistan
    Default help,,,,Boknoy_ph/masood
    I am using win XP.when i download S/W into my stb the pc gives me the message(opening port error) what should i do, thanx in advance
    Abdur-Rehman Dawar.
    Ali4u
    Disconnect your Dial-up connection and then try to update your reciever ...I hope your problem is solved ...do it and let me know.
    make sure the comport settings on your control panel/system/device manager/ports corresponds to that of your loader software.
    Jul 2005
    saudi arabia
    go to control panel/system/device manager/ports/properties then update the driver maybe your driver is corrupted.
    Lahore
    Default Re: help,,,,Boknoy_ph/masood
    Quote Originally Posted by dawar098
    If you want to know the port setting with USB to Serial converter then I'm sorry to say,,it doesn't work with me
    Fte Max 100S
    Humax IRCI-5400z
    Nov 2005
    Mr.totingph
    i tried your instructions.but didn`t find result.Again it gives me the message....input file open error...in more info...it tells....YOU CANT DOWNLOAD BECAUSE YOUR STB AND DOWNLOAD FILE OF SYSTEM INFORATION DO NOT THE SAME.
    Any RDI friend who can help!
    Abdur-Rehman Dawar.
    which receiver do you have anyway?
    Nov 2005
    technosat bodyguard 555
    Abdur-Rehman Dawar.
  1. to boknoy_ph please help
    By newone in forum RDI - English
    Last Post: 25th October 2006, 04:20
  2. boknoy_ph plz help
    By deutsch in forum RDI - English
    Last Post: 21st October 2006, 23:43
  3. If Masood online (Masood Or Other Experts)
    By zsaad1111 in forum RDI - English
    Last Post: 3rd July 2006, 11:02
  4. Replies: 5
    Last Post: 1st December 2005, 10:19
  5. DECODER V/S DTH Boknoy_Ph
    By dawar098 in forum RDI - English
    Last Post: 22nd November 2005, 17:30
