Results 1 to 3 of 3
    Nov 2005
    Default Dreambox 7020 issue with S-vhs out on SCART connector
    Hi all,
    Did Anyone experience colors (lack of some to strong on others) when output s-vhs signat on Dreambox 7020 TV SCART.
    This happens with a Panasonic plasma display wich works perfectly with s-vhs from a DVD player (same cables).
    Any ideea (I've changed several images, no differece) I think it's hardware. Shold I swith to SCART component ?
    thks in advance.
    dgavrile
    May 2004
    try to use it with SCART, i hope it is not PAL/NTSC problem with you S-VHS out
    Nov 2005
    Default S-vhs bad signal on Dreambox SCART still an issue
    Saed,
    Thanks.
    It's not unfortunatelly a multinorm issue and also it's not a cable or connector issue either. when i tried manually with separate wires based on a connection schema (SCART to s-vhs coonectors) I got the same bad colors.
    Panasonic plasma works perfectly on DVD s-vhs signal and it doesn't have SCRT connector (only 4 pins s-vhs unfortunatelly).
    I was wondering I can get from Dreambox component signal on SCART and use an adapter for plasma. Is this what you wanted to tell me ?
  1. dreambox 7020 s-???
    By myky in forum DREAMBOX
    Last Post: 10th October 2006, 20:25
  2. Dreambox 7020 defect ???
    By pintenogu in forum DREAMBOX
    Last Post: 2nd July 2006, 22:59
  3. ora din dreambox 7020-s!!!!
    By bilutza neagra in forum DREAMBOX
    Last Post: 3rd April 2006, 00:32
  4. Help Dreambox 7020 S
    By Axell in forum DREAMBOX
    Last Post: 2nd February 2006, 23:44
  5. Replies: 7
    Last Post: 9th December 2005, 18:46
