Results 1 to 2 of 2
    Nov 2005
    Default boknoy_ph need ur kind help
    boknoy_ph saya
    try the file from this site http://onlyfunintown.250free.com/. all you need is the full backup. no need to reload the patch file for full-x since it disables your built-in CI slot. your full-x will still work after this patch is loaded coz the sky chip info has been updated already. then reload with dreamsoft. hope it works this time.
    Dear friend bo noy according to ur advise i did as fallows :
    1. after installing full meta box file I re install the DS but the problem is still there when i go to tune satellite . it shows the signam but dosnt store the channels ..
    2. then Installed the 2400 bin file with channel data .
    but after this it again hides the smart card option .
    Plz help me I have tested one by one almost many meta and Ds softwares.
    Now I have come to know as I down load full meta box 3 softwares .
    I shall be very thankful for ur kind help .
    ur friend Khalid
    Nov 2005
    Default hi
    hi
    I m waitng for u boknoy_ph.
  1. to boknoy_ph please help
    By newone in forum RDI - English
    Last Post: 25th October 2006, 04:20
  2. boknoy_ph plz help
    By deutsch in forum RDI - English
    Last Post: 21st October 2006, 23:43
  3. What kind of a forum is this
    By pfloyd in forum RDI - English
    Last Post: 8th July 2006, 14:50
  4. What kind of DVB PCI card is this? help
    By CyberBRO in forum RDI - English
    Last Post: 25th May 2005, 11:33
