Page 57 of 58 FirstFirst ... 74755565758 LastLast
Results 841 to 855 of 864
Thread: Vu+ Uno
  1. #841
    De ce nu instalezi IPTV Player, este merge mult mai bine decât Kodi...eu zic ca problema este de la plugin, nu am mai încercat dar știu ca si mie mi-a făcut figuri Kodi Direct la instalare.
    Sent from my iPhone using Tapatalk
  2. #842
    Sep 2007
    eu as renunta fara probleme la kodi doar daca as avea pentru 990 .ro ceva alternativ. ceva gen hd4all pentru mediaplayere.
  3. #843
    Inimos din cale afara Expert
    in my own mind
    Am observat ca si citirea filmelor cu media playerul inclus e deficitara. Nu stiu... cred ca tot flashul original e mai ok decat aceste improvizatii de extindere. Vu+ Zero are memorie interna mai mare? Nu m-am uitat la specificatii
  4. #844
    Default OpenBH 0.6 Vu+ Uno
    OpenBH 0.6
    Whats New:
    • Completely new image, now much more compact and lightweight than ever before
    • Switched to new Enigma2 base
    • Added BH SpeedUp panel (so you can add or remove some features)
    • Updated to Inadyn-mt
    • Updated OpenMultiboot (now shows image names on front panel display)
    • Updated to Gstreamer 1.9.0 (GIT)
    • Updated to OE3.4 core
    • Updated to Python 2.7.11
    Main Features:
    • MX HQ9W Full Hd skin (1920x1080)
    • Kodi and Youtube Tv (for those models that support it)
    • Chromium OS or Opera (for those models that support it)
    • HbbTv (for those models that support it)
    • OpenMultiboot (all Vu+ models supported)
    • OE-A Plugins
    Black Hole:
    • Blue panel
    • Green Panel
    • Extra Settings
    • Addons panel
    • SpeedUp panel
    • OpenSSL patched for backwards compatibility with some plugins
    • Compatible with OE-A and PLi plugins and Skins
    What is OpenBH ?
    It is an exciting project from the same team that produce the Black Hole images.
    This latest project is now based on the OE-Alliance git and coding infrastructure, which means it is not only Open Source, but it is also compatible with all OE-A and PLi plugins, feeds, skins and it also features full online update support (for those users that do not like having to do a full reflash everytime there is an image update). We have just given it the Black Hole touch.
    This means it has the Green Panel and Blue Panels as found in the previous Open BlackHole and the standard Black Hole images, we have also added the BlackHole addons panel and included Full HD skin support..
    As with the standard Black Hole images, we continue to support Genuine Vu+ Boxes only and therefore our images are optimised for Vu+ boxes and will only work on these models (any openBH, Open BlackHole, or Black Hole images you see on the internet for other box models or clone models are not official images and we offer no support for those boxes or images).
    Do I have to upgrade to this new OpenBH image ?
    No you don't have to upgrade to the new OpenBH image, this image is completely separate from the original Black Hole image, this is simply an alternative image so we can offer our users more choice, if you are happy with your current image, then you can continue to use that image, if you want to try the new openBH image then you can do so.
    What about the Black Hole and Black Hole Prism Images ?
    For those of you worried about the standard Black Hole and Prismcube image, please don’t worry, we remain committed to the standard Black Hole and Black Hole Prism images and image updates will continue as normal, this new OpenBH image is an additional project and we are fully committed to all images.
    Where can I find the OpenBH git ?
    The OpenBH git is located here: https://github.com/BlackHole
    DISCLAIMER
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY EMULATOR, K E Y S, SOFTCAMS OR OTHER SYSTEM FOR VIEWING PAY - TV WITH OR WITHOUT A PAID SUBSCRIPTION.
    THE OPEN BH IMAGE DOES NOT CONTAIN ANY SYSTEM TO DOWNLOAD PLUGINS OR EMULATORS FROM EXTERNAL SERVERS OR SOFTWARE THAT MAY BE USED FOR ILLEGAL PURPOSES SUCH AS CARD SHARING.
    openbh-0.6-vuuno-20160627_usb_release_dfa51a6.zip
    File size:68.5 MB
  5. #845
    Jul 2003
    de ceva vreme ambele receptoare vu se blocheaza random pe orice canal, la un zapping mai riguros sau pur si simplu. am schimbat HDD/stick, imaginea reinstalata de vreo 3-4 ori. A trecut inapoi la VTI acolo merge saptamani intregi.
    setup-ul actual e BH in flash si VTI / OpenPLI / OpenSPA pe stick. dintre toate imaginiile de pe stick VTI e singura care nu se blocheaza !
    mai are cineva problema asta ? orice sfat e binevenit.
    La fel si cand esti prost ...
  6. #846
    May 2014
    undeva pe pamant
    Pune un hard disk de capacitate sub 500 gb. De acolo iti vine baiul. O sa spui ca nu are nici o legatura , dar incurcate sunt caile domnului
  7. #847
    Jul 2003
    Quote Originally Posted by niscu View Post
    hdd e de 80 GB pe ambele ! si fara hdd face la fel
  8. #848
    in my own mind
    Al meu a mers atatia ani cu HDD de 750 gb.... nu a fost nici problema. Acum insa da rateuri la greu si reinstalez imaginea la 2 saptamani. Cand s-o duce, s-o duce. A ajuns o conserva si el...
  9. #849
    L'amerique du nord
    @skyclinere - de ce nu il repari ?
  10. #850
    in my own mind
    nici nu mai vad cum trebe, nici rabdare nu mai am ca alta data... e greu de inteles si pentru mine
  11. #851
    L'amerique du nord
    trimite-l lui @the the sau @webman ca ei sint mari fani vuminus...ti-l fac pe gratis
  12. #852
    MuSic & So mucH MoRe! Expert
    Aug 2003
    Svishtov
    Quote Originally Posted by pop_eye View Post
    Dear Mr. pop Eye, nu sunt fan niciun box. Ce are unul, n-are altul si tot asa...dar daca vrei sa discutam despre bune si rele la diverse receptoare, te invit la o bere, cafea, etc. cu ele pe masa, la teste. Asa doar sa discutam teoretic, sunt satul...toti isi dau cu parerea "de pe net" ca de, e gratis.
    Merci de intelegere.
    DVB-S:
    Offset Emme Esse (Alu.) 1.25
    Offset Emme Esse (Alu.) 1.15
    DVB-T:
  13. #853
    Default Black Hole 3.0.3 Vu+ Uno
    Merry Christmas from the Black Hole Team
    Black Hole 3.0.3
    What is new ?
    - Add Support for Uno4K and Ultimo4K
    - Update default skin MX HQ10 for extra tuners
    - Update skin api
    - Update OpenMultiboot
    INFO: This Image has the latest drivers but CAN be installed in OpenMultiboot. The image does not need to be installed in flash.
    This latest version of the Black Hole series has been updated and improved for maximum stability and performance.
    - Integrated OpenEpg
    - Rytec dedicated epg.dat
    - New system epg.dat outside.
    This last feature offers the possibility to various forums or communities to create their favorite EPG data files and load them into a web space.
    Download EPG from any channel
    Yellow button = Audio menu
    Addons
    Infobar / OSD
    Analog Clock Gui
    Channel orbital location
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    Telnet Panel ( Telnet Panel)
    FTP Panel ( FTP Panel)
    UPnP Client Djmount
    UpnP Server Minidlna
    Pcsc Panel
    Tuner Server
    Network Browse & Mountpoints
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Online Feeds Settings update
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    Thanks to plnick for help obtaining missing Ultimo4K files.
    Thanks to Pedro_Newbie for Backup script.
    Thanks to [email protected] for the file satellites.xml.
    Thanks to Littlesat and Pli Team for the original autolanguage and subtitle options code
    DISCLAIMER
    LICENSE (TERM OF USE)
    BlackHole-3.0.3-vuuno_usb_release_20161224_d3f1586.zip
    File size:79.4 MB
  14. #854
    Default Black Hole 3.0.3.D Vu+ Uno
    Black Hole 3.0.3.D
    What is new ?
    - Update default skin MX HQ10 to fix font issue's with Ultimo4K
    - Update drivers (solo4k, uno4k, ultimo4k)
    - Update libvugles2
    - Update Satellites.xml, Cables.xml and Terrestrial.xml
    - Update Danish, French, Italian, Lithuanian, Norwegian, Polish, Portuguese and Spanish translations
    - Update epgcache for MHW2
    - Update OpenWebif
    Addons
    Infobar / OSD
    Analog Clock Gui
    Signal SNR, BER
    Infobar picons
    Blue Panel
    Extra Settings
    Black Hole Speed Up
    Devices Manager
    Usb Format Wizard
    UPnP Client Djmount
    Pcsc Panel
    Tuner Server
    Info Panel
    3 - About (info)
    Memory (Memory)
    Space (capacity)
    CPU (processor)
    Process (process)
    EPG Panel
    Green Panel
    Addons (added)
    Red Panel
    BlackHole
    Avalon
    Chaos
    Ghost
    Credits
    DISCLAIMER
    BlackHole-3.0.3-vuuno_usb_release_20170127_371b7f5.zip
    File size:81.7 MB
  15. #855
    Default OpenBH 1.0 Vu+ Uno
    OpenBH 1.0
    Whats New:
    • Updated to OE4.0 core
    • Updated to Python 2.7.12
    • Updated to Gstreamer 1.11.2 (GIT)
    • Automatic backup before online update
    • Option to view changes before online updating
    Main Features:
    • MX Titanium_C Full Hd skin (1920x1080)
    • Kodi 17.1 (for those models that support it)
    • Fallback - Fallback tuner settings moved to Service searching menu into its own menu
    • Fallback - Remote bouquets copier (Channel Importer). For receivers used as clients, copies and loads the channel list from the server box.
    • Fallback - ability for client to not write EPG data back to server box. Means epg.dat can be shared over a network mount without fear of corruption.
    • Various OE-A Core updates.
    • Updated Service Info screen
    • Updated Streaming Clients screen (skin dependant)
    What is OpenBH ?
    DISCLAIMER
    openbh-1.0.001.release-vuuno_usb_release_08eb6e0.zip
    File size:63.7 MB
