    Mar 2009
    Thumbs down Dreambox 500 BIG PROBLEM
    hallo
    I have a problem with dreambox 500
    When you want it Flasch over DreamUp is unable to make flasherase.
    Whether through another program to make flasherase
    Always throw:
    COM: The hardware detected a break condition.
    14:32:01 box type: DM500
    14:32:10.249 server: got discover packet, ip 0.0.0.0, baud 115200
    14:32:10.259 server: ATTACHED box!, temporary, ip 0.0.0.0, baud 115200
    14:32:10.369 Ping result: OK, box is alive and speaking to us
    14:32:41.979 erasing complete flash (without bmon stage of course)...
    14:33:12.520 server: retry 1
    14:33:13.530 server: retry 2
    14:33:14.540 server: retry 3
    14:33:15.550 server: retry 4
    14:33:16.520 ERROR, flash-erase failed, box will be unusable now
    T H A N K S
    Dec 2007
    aproape de tine...
    Debifeaza reteaua in DreamUP si incerca sa incarci imaginea din nou prin rs232 cu un cablu nullmodem.
    Incearca diverse versiuni de dreamUP, ultima versiune se intrerupe pe dm500 in timpul incarcarii.
    Bafta !
    Notă: Vizionarea programelor Pay TV fără un abonament valabil este ilegală
    Discuţiile purtate si fişierele disponibile aici sunt în scop experimental şi educaţional !
    Dec 2007
    nowhere
    Try an old version of Dream Up.
    EXPERT GIGABLUE & IPTV Expert
    Feb 2010
    da ti ex si o vers ca asa cauta de nebun la vers
    dreamUp_DM500 V2.18a
    http://www.2shared.com/file/e-1T-kyV/dreamUp_DM500.html
    Mar 2009
    Default x
    hallo
    dreambox 500 clone
    when I want to make DreamUp flash with erase this image DreamUp articles
    9:04:11 Found no valid JFFS2 in image, flash-erase not supported
    Does anyone know what to do THANKS
    Super Moderator Expert
    bucharest
    jtag my friend,i supose is single solution for you!
    Oct 2011
    The most well-known recipient may be the hd a single made by Fantasy Multimedia system has been dreambox DM 800 which usually later on became the ideal vendor within the satellite tv industry.
