Results 1 to 2 of 2
    Nov 2005
    Default PROBLEM DIGITALLWORLD SCI 190
    PLS HELP ME
    NO UPGREAD MY RECEIVER DIGITALLWORLD SCI 190
    UPGREAD CODE CHANGE MACGE LAST UPGREAD CODE (lovedw) not
    accepte pls argent help new code ?
    Default Re: PROBLEM DIGITALLWORLD SCI 190
    Quote Originally Posted by homax8585
    PLS HELP ME
    Hello homax8585
    Please follow instruction carefully as per readme file direction:
    1. Decompress the downloaded file.
    It includes 2 files and 2 directorys.
    DWSUv34.exe : KEEP it for future application download.
    readme1st.txt : help file.
    inc directory : contains the include file.
    bin directory : contains the binary image file.
    2. Connect the serial cable between your PC(COM1) and the Set-Top Box.Check the serial port can work well and COM1 port.
    3. Check the SetTopBox is turn OFF
    4. Double click the download program(DWSUv34.exe).
    5. Type the PASSCODE "lovedw" inside the memo box area.
    6. Now, turn on the SetTop Box.
    7. Then the progressive bar in the download window works. And the SetTopBox dispalys "dnLd" and "Upgd" cascadely.
    8.Lastly, the Message box in PC shows "Congraturation. Software Upgrade OK ". Confirm it.
    9.Then, Turn OFF and ON again the SetTopBox.
    Download the files form here:
    http://pinoycourt.com/viewtopic.php?p=122#122
    Best Regards
    Dody
    www.pinoycourt.com
  1. NEED HELP! DIGITALLWORLD
    By mgrace in forum RDI - English
    Last Post: 11th June 2008, 14:35
  2. Digitallworld
    By bublu in forum RDI - English
    Last Post: 15th October 2006, 15:22
  3. Replies: 6
    Last Post: 29th July 2006, 21:39
  4. Digitallworld SCI 190 Channels Problem?????
    By majidpsh in forum RDI - English
    Last Post: 10th October 2005, 14:24
  5. Au for SNA-951 DigitAllWorld
    By alegsus in forum RDI - English
    Last Post: 11th June 2005, 05:33
