Results 1 to 9 of 9
    Sep 2007
    Bucharest
    Default Vand receiver Optipox Alligator DVB-S2 si DVB-T HD - 650 RON
    Pretz 650 RON
    Garantie pana in noiembrie 2011 la digital satelit
    Are instalat ultimul soft, inclusiv oscam.
    DVB-S/S2 Tuner And Channel
    RF Input Range: 950MHz ~ 2150MHz
    Input Connector: F-Type Female (With Loop-Through Output)
    Input Impedance: 75[Ohm]
    Input Dynamic Range: -65dBm ~ -25dBm
    Multi Demodulation Standard: DVB-S, DVB-S2 : QPSK, 8PSK
    Symbol Rate: DVB-S : QPSK Maximum 45Msps @ 2~45Msps
    DVB-S2 : 8PSK/QPSK Maximum 30Msps @ 10~30Msps
    Multi Decoding Method Standard: LDPC/BCH DVB-S2(1/2, 2/3, 3/4, 3/5, 4/5, 5/6, 8/9, 9/10)
    DVB-S/S2 MPEG TS A/V Decoding
    Transport Stream Format: MPEG-4 Part10 AVC/H.264 HD [email protected] [email protected](ISO/IEC 13818 MPEG-2 TS Specifications)
    Profile Level: MPEG-2 [email protected], MPEG-4 Part10 AVC/H.264 HD [email protected]
    Input Rate: Maximum 90Mb/s
    Video Aspect Ratio: 4:3, Letter Box, 16:9, Pan & Scan
    Video Display Resolution: 1920x1080i, 1280x720p, 720x576i/p, 720x480i/p @ 50/60Hz
    Audio Decoding Format: Dolby Digital bit-streams, MPEG-1 Layer 1,2,3
    Audio Output Mode: Mono, Left, Right, Stereo, Dolby Digital bit-streams(PCM 5.1 Channel, Stereo down-mixed Dolby ProLogic)
    DVB-T Tuner And Channel
    RF Input Range: VHF-High Band 149.5MHz ~ 426MHz,
    VHF-Low Band 50.5MHz ~ 142.5MHz, UHF-Band 434MHz ~ 858MHz
    Input/ Loop-Through Output Connector: 1 x Din Jack for DVB-T, 1x Din Jack for DVB-T Loop-Through Output
    (IEC 169-2 Female/Male)
    Input Impedance: 75[Ohms] Nominal
    Input Signal Level: -80dBm ~ -5dBm(64QAM, Code Rate 2/3, Guard Interval 1/32,
    Gaussian Channel)
    Digital Modulation Scheme: QPSK, 16-QAM, 64-QAM(Constellation)
    Guard Interval: 1/4, 1/8, 1/16 and 1/32
    Modulation Mode: 2K, 4k, 8K modes
    Supporting System: DVB-T(COFDM) Compliant (Frequency Band Modulation) ETSI 300 744
    IF BandWidth: 6/7/8MHz channel
    FEC Code Rates: 1/2, 2/3, 3/4, 5/6, 7/8
    DVB-T MPEG TS A/V Decoding
    Transport Stream Format: MPEG-4 Part10 AVC/H.264 HD [email protected] [email protected]/60Hz(MPEG-2 ISO/IEC 13818 Transport Stream Specification)
    Input Rate: Maximum 31.668450Mb/s, 27.709893Mb/s
    A/V And Data Output
    Analog Component YPbPr: 1 Set(3xRCA Vertical Array Type)
    CVBS(Composite Video), Stereo Audio: 1 Set(3xRCA Vertical Array Type)
    S/PDIF Dolby Digital Interface: 1 Optical(Fiber Optic Type)
    HDMI (with HDCP Option): 1 Connector
    SCART Interface: TV/VCR
    USB2.0 Host Interface: 2 USB A-Type Connector
    Ethernet: 1 Connector RJ-45 10/100 Base-T
    RS-232C Data Port D-Sub9 Interface: Transfer Rate 115,200bps(Firmware Upgrade Port)
    Conditional Access Interface
    PCMCIA: 2 Slots For DVB Common Interface Standard
    Smart Card: 2 Smart Card Support
    Storage Device
    SATA(Serial ATA): 1 External eSATA Port
    System Resource Information
    Main Processor: 300MHz MIPS32TM/16-e class CPU
    Flash ROM: Default 32Mbytes
    DDR SDRAM: Default 256Mbytes
    Power Supply
    Input Voltage: AC 100-240V ~ 50/60Hz
    Power Consumption: Maximum 35Watts
    Protection: Separate Internal Fuse
    Type: SMPS(Switching Mode Power Supply)
    Safety And EMI: For Country Regulation
    Physical Specification
    Dimension(WxDxH): 340x268x60[mm]
    Net Weight: About 3.0Kg
    Operation Temperature: 5C ~ 50C
    Storage Temperature: -40C ~ 65C
    Sep 2007
    Bucharest
    UP UP UP! negociabil...
    Sep 2007
    Bucharest
    pret de criza, 550 RON, pt un un receiver cu 2 tunere,, dvb-s2 si dvb-t HD..
    Sep 2007
    Bucharest
    450 ron , ultimul pretz, pt un receiver hd cu 2 tunere satelit si terestru hd..
    Sep 2007
    Bucharest
    350 ron ...pt 2 tunere, satelit + terestru hd..
    MuSic & So mucH MoRe! Expert
    Aug 2003
    Svishtov
    Smile
    Deja e aproape cadou!
    Dacă reușesc să vnd din ale mele n perioada asta te rezolv plus bere!
    Nu ai nevoie de un multifocus sau un Inverto Black octo?
    Thanks.
    DVB-S:
    Offset Emme Esse (Alu.) 1.25
    Offset Emme Esse (Alu.) 1.15
    DVB-T:
    Sep 2007
    Bucharest
    din pacate nu am ce face cu ele..si aparatul e al unui amic
    pot sa te asigur ca e impecabil, oricum mai mult a stat decat a mers..
    Apr 2009
    Default Intrebare!
    Acest receiver functioneaza si ca client CCcam,si daca da,este stabil in functionare?M-ar interesa un receiver cit mai ieftin la pret si sa-l pot lega ca client la DM 800!
    Sep 2007
    Bucharest
    s-a vandut
    se poate sterge/inchide.
