Results 1 to 2 of 2
    Jan 2011
    Default Reception problem with dreambox 800 and 3G router
    Every 15 minutes or so, the picture would freeze/pixilation for 5-10 seconds. Seems like the receiver is requesting information from the server so there is a lag. After 2 or 3 times, the picture would freeze and I have to standby the receiver before turning it on again. The situation is improved when I change the ppp settings of the router from “on demand” to “auto” but the picture would still freeze ultimately(maybe after slightly more than 1 hour). 3G signal strength is full and network test is ok.
    Look forward to advice. Thank you
    Oct 2011
    The actual show of the dreambox dm800 Hi-def has excellent physical appearance. Generally, the show than it will get incredible OLED exhibit.
