    21.95° N 97.06° E
    Default Problem Connection with Window 7 and DM 500s
    Hi all friends , i've problem on connection with DM and Window 7 . i can't connect via Lan and Wireless .it's connection fine on my another laptop which is using window XP . May be some other hints on window 7 and i want to know how to do . Plz. help me brothers .
    Regards.
    Yan.
    " 李俊明 Born To Help People "
    21.95° N 97.06° E
    Also i want to know how to check the IP in window 7 coz. it's only showing hex ( i think ) numbers when i check ipconfig .
    Thx.
    Feb 2006
    I use dcc ,win7,dm800 and working very good.Do you have ping response to DM IP?Your IP class on win 7 is the same class with DM (ex.192.168.1.xxx)?
    DM 500S,Hyundai Digicablu,Humax DIGI C HD,Diablo CAM,VU+ UNO,HH DM3800s,Triax TDA110,Inverto single black
    Oct 2007
    Bucharest
    Hello,
    You must take a closer look on ipconfig command results because you must have the correct answer on the first rows. The other rows are IPv6 addreses but they are not neccessary for you. You must use the following basic steps to find what is your problem:
    - first you must find your DM ip (maybe from Blue Pannel). I suspect that you have DHCP ip allocation on your DM and your new ip address is unknow to you.
    - after you have find the DM ip address then you can use the ping command from your cmd window.
    Bye
