Results 1 to 10 of 10
    Default Driver Help for DVB-PCI Card!
    Hi People!
    Well I got the [email protected] DVB PCI Card and I installed it. Got the drivers off PentaMedia Website and installed it. Installed PROGDVB but it does not detect my card. So is there any driver which is compatible with my PCI DVB Card and is recognized by ProgDVB? What are these BDA Compatible drivers and where do I get them from?
    Anyone willing to help a newbie?
    Thanks
    Sumit
    your pentacard is listed among the bda compatible card. just load your drivers off pentamedia, and configure progdvb to run with the bda compatible drivers after installation. after which, run progdvb and select your card from the list and activate it.
    Default Failed on Windows 2003. Will try on Windows XP and get back
    Hi!
    Thanks for your prompt reply. I did what you told me but it was on Windows 2003. I am loading Windows XP on a spare machine and will give it a shot. In Windows 2003 ProgDVB says that BDA Device is not present.
    If this fails, can i try the Twinhan drivers? If yes, from where can I get those drivers?
    Regards
    Sumit
    progdvb has it's own twinhan compatible drivers, just reinstall progdvb and select twinhan from the drop down menu. or you may get it from www.twinhan.com.tw
    You need to load the twinhan multimedia controlers into Windows (XP is the best bet for most dvb application) before you load progdvb or any app like this, this will be on your twinhan cd (that came with your card or usb device) or dload from the twinhan web site in the usa or taiwan.
    Make sure that it is loaded and winman is running the first time you load progdvb as it will auto detect your twinhan device.
    Good luck
    Default No Luck
    I tried the [email protected] Drivers with Windows 2003....no luck
    Twinhan drivers with 2003....no luck
    [email protected] drivers and twinhan dribers with XP...still no luck
    Now, from where do I get the Twinhan Multimedia Controllers? I have absolutely no idea which software is this...any url?
    Please help!
    Regards
    Sumit
    PAKISTAN
    change your dvb card.. and buy Technisat Skystar2..All rounder,No driver problems..even linux support
    Default Thats what i am going to do....but.....
    Well anyways....i am giving up (for the time being) on the [email protected] card. I am looking for the Skystar 2 card but its not available in India (or is it?). I have an option to go for the original Twinhan card. Will be placing an order for the Twinhan. In the meanwhile, if someone can make the Skystar available to me in India for a decent price, I will go for that instead.
    Regards
    Sumit
    Default Re: No Luck
    Quote Originally Posted by SumitB
    Please help!
    Regards
    Sumit
    As per this message
    Good luck
    Eyes wide open..
    Default Doubts about [email protected] Card!
    Now I have my doubts about the capabilities of the [email protected] card I have. When I had got this card, it was only used to get One-Way Internet. The software it came with did very well with the card and I used to get the job done. I was using Agila-2 C Band with a subscription from Hawaii Teleport. Now it is no longer need for internet and so I decided to use it for television.
    The [email protected]alue website http://www.pentamedia.com/eng/product/receiver.php# suggests that it is for high speed data and does not mention anything about television. Other websites manufacturing such cards like twinhan and hauupage specifically mention that their cards can do data and television. So can my card be used for television in the first place? If yes, can it be tested with some ordinary software to get FTA before I can try a program like ProgDVB?
    The software that comes with the card has no option to view any channels.
    Anyone please provide me with detailed instructions.
    Regards
    Sumit
  1. Replies: 1
    Last Post: 16th July 2006, 02:26
  2. Replies: 0
    Last Post: 10th July 2006, 01:11
  3. Nou driver 4.3.2
    By miste_R in forum Placi DVB
    Last Post: 27th October 2005, 06:35
  4. ss2 4.2.11 driver
    By gogi in forum Placi DVB
    Last Post: 18th October 2004, 13:37
  5. driver ss2!
    By vulcanescu35 in forum Placi DVB
    Last Post: 30th May 2004, 19:45
