    Satellite Internet Expert
    Default boknoy_phill need ur help for dvb channels at network
    dear friend,
    iam using 2000 windows server with isa server, i installed prog dvb client/server module in server and in clients system.it works well at uni cast option and only one client can see the channels at my net work .
    when two clients try to watch the channels it stops on other.
    there r options in sever module.
    protocol ...unicast/broadcast/multicast
    multicast group ip......................
    port 10999
    when at server and at client end uni cast option is used the channel works well at server and at client too, but only at one client.when 2nd client connects to it the 1st one screens goes blank.
    dear what should be the options in server and in client modules that at the same time maximum clients can watch the channels by it.
    hope u plz will explain it to me
    thanks
    uni = one. multi = more than one. simple as that. the number of clients able to view depends on your bandwidth from the network.
    sir i dont know how to check my network bandwidth,iam using wireless lan with stp cat 5 e cable .
    iam asking what setting should be at server,in module settings.and what setting at client end in dvb module device,plz tell me in detail
    Quote Originally Posted by SHELLEYATICD
    You read the message when you selected multicast right - email the author or the commercial version.
    To multicast across the LAN, WAN and wifi and we use http for this we use TSreader and VLC for the purpose.
    You can set the bandwidth and all the codex you require in VLC (this is an open source, milti platform application - do a google on vlc and select the first option - it will stream any media i.e dvd, vdc, cd, tv, anything you put up as a stream etc)
    We run anywhere up to about 200 clients on a typical 100mbits LAN and more of course on a 1gigbits LAN.
    Consider buying the media plugin from progdvb or do the TSreader route.
    Good luck - I simply love IPTV
  1. Replies: 30
    Last Post: 9th August 2006, 01:22
  2. ALL STAR TV CHANNELS NOW ON ZEE'S DISH TV NETWORK
    By kamal777 in forum RDI - English
    Last Post: 17th July 2006, 01:10
  3. SKY NETWORK
    By MARCATION in forum RDI - English
    Last Post: 10th June 2006, 18:45
  4. Network(TM) Expands HD Lineup to 29 Channels
    By first_zipper in forum News
    Last Post: 10th June 2006, 06:38
  5. Cartoon network, boomerang and other toon channels
    By Strathisla in forum RDI - English
    Last Post: 18th August 2005, 05:37
