Results 1 to 9 of 9
    satdoctor Teacher
    Peshawar Pakistan
    Default Difference b/w HD LNB and old Normal KU LNB?
    In market nowadays most of universal Lnb's are labelled as HD KU LNB's.. Are they really make a difference if yes then in which way are they different from normal old ku lnb's ? is signal coming stronger in these hd lnb's ? or any other difference . ? plz tell me if anyone knows here
    AIM
    there is no difference.
    Africa-Kenya-Nbi
    There might be other differences in gain, freq range etc,
    which existed even before,
    but nothing so significant.
    Aug 2007
    RANGOON
    Question
    Bro cogil,so u means we are get the HD channels using normal LNB is not very different?
    Stop Using Plastic Bags!
    Using 5R to Protect Our Green Planet
    Reduce,Reuse,Recycle,Reject & Return
    and the question gets asked again, in a different way.
    you CAN get HD channels from your "regular" lnb provided it is within the frequency range. nothing special about that. end of story. what you need is an HD receiver to watch the channel.
    1. do you need a "HD" lnb to view HD channels? NO
    2. do you need an HD receiver? YES!
    maybe somebody will buy HD lnb and attempt to watch it from his analog receiver, come back here and complain that he cannot watch his channels even if he has "HD" lnb.
    satdoctor Teacher
    Peshawar Pakistan
    Default thanks
    Thanks for Kind info ..dear I knw that we do need hd reciever to watch hd channels . i was just talking about signal of DVB-S2. Coz i use Technisat SS2 and i can watch hd channels with it by just changing HD Codec but can not recieve signlas of DVB-S2 Transponders thats why i asked it . Anyways thanks indeed for kind info .
    AIM
    Africa-Kenya-Nbi
    Quote Originally Posted by mintun View Post
    yes we get HD using normal lnb.,
    Faithful Member Expert
    Sep 2008
    is only a matter of marketing, there is no difference between a called "hd" lnb and a simple lnb
    Cheers
    Vu+ Ultimo4k / Vu+ Solo2
    Lahore
    in other words "HD" is a brand of KU lnb nothing special in it.
    @noy and cogil
    how are you?
    let me
    Fte Max 100S
    Humax IRCI-5400z
