When using WINCSC IN progdvb with CSAT i have got problem with channel other then the four C + the ECM showed in the channel properties just shows the ECM 0082 or 0089 (for k i o s q ue) but the ECM needed is 0080 it works in other soft like ALT dvb or my theather (I see the 0080 ecm and i can change it) but in progdvb not luck it doesn't work if i put it manualy (wincsc doesn't find any CAID on "the right ECM"
Why progdvb doesn't send the ECM putted manualy other then the one's listed ?
thanks for help ...
