Results 1 to 15 of 16
    Jun 2010
    Default DM 7020 probleme
    Am vazut ca si alti utilizatori de Dm 7020 au mai avut probleme, asa ca poate ma ajuta cineva sa rezolv problema. Multumesc anticipat!
    Deci: am in flash imagine originala iar pe usb am pus atat imagine Enigma1 Nabilosat cat si Enigma2_Pcd_2.2 . Daca rulez cu E1, cam la 4-5 ore se blocheaza, daca merg cu enigma2 merge ceva mai mult. Am incercat si cu imagine enigma1 direct din flash, iar timpul de functionare scade cam la 2-3 ore. Atunci cand se blocheaza atat cardul, imaginea cat si partea de sharing merg.
    Inca odata multumesc pentru orice sfat.
    Aug 2003
    Karlsruhe- Arad
    @neovox
    Eu unul cred ca Tu confunzi ceva - sau te ai gresit la scris DM 7020
    DM 7020- este E1 , ceea ce inseamna ca NU poate sa mearga cu E2
    in mod normal nici nu poti instala
    Daca intradevar ai un 7020- si vrei sa faci ce zici- sau cum inzeleg eu - Multiboot - atunci baga o carte CF- in fatza linga locul de Module
    si cu Flashwizard poti pune cite imaguri doresti
    numai ca in flash trebuie sa ai un CVS - de boot- ptr. DM 7020
    Jun 2010
    buna,
    sigur nu gresesc. uite aici:
    DM7020 Enigma2 Pcd 2.1
    Here is the new updated version of the Enigma2 TestImage- hope you like it.
    New
    Multiepg with timer using plugin EPGImport
    Default skin : Vali-Kingsize with Atlantis, Avalon, BeyondDreams, Glas. MetalPads, Validator etc
    Skin transparency adustment
    New skins Infinity mod, LT6 mod
    Updated Extramenu
    Updated and new plugins e.g PartnerBox, Youtubeplayer, ZDFMediathek, Pauli etc.
    Features
    enigma2-2.8git100503
    Quick-buttons
    Blue (short press) - Extra setup
    Blue (long press) - Extensions
    Power (short press) - Standby
    Power (long press) - Shutdown menu
    INFO (short press) - event info
    INFO (long press) - Graphical multi epg
    Led
    Standby - red led
    Recording - blinking red led
    Please note :-
    This image is particularly suitable for installing in flash.
    If installing in flash - it is very important use the feature "Increase available memory" soon after first bootup.
    To keep the image size small - only the minimum software is included in the image. So - please install the Basic Pack Software before installing any plugin.
    The image can be installed on multiboot, but the flash image has to be recent (new cvs).
    Note: When you remove (uninstall) a skin via Addon Manager - check that it is deleted from /usr/share/enigma2. Sometimes ipkg remove does not work completely !
    Extra Setup includes
    Readme (very important). All Readme files are in folder /etc. Please copy and translate (with google for example) if necessary.
    Softcam-manager
    Increase memory : Necessary for flash install
    Addon-manager : Download and install addons
    Software : Additinal software items necessary for plugins
    EPG : configure EPGImport
    Subtitles : Change ttx subtitles size and colour
    Media/MountManager : Cifs and Nfs mount configure,
    MountManager,
    User-Script manager
    Inadyn, Pmt.tmp, Crond configure
    Picon
    Date language : Change date language
    Streaming media from pc to dreambox : vlcplayer, youtubeplayer etc.
    Streaming tv to pc : Install webinterface. On pc open webif browser.
    Click on tv icon. Select Open to start VLC.
    Configure VLC 0.8.6 :- Settings - Preferences - Iinterface-Main Interface - Select Advanced - Select HTTP and in HTTP Hostaddress insert :8080
    Settings - Preferences - Video - Select Fullscreen output
    Settings - Preferences - Stream output - Default stream output chain - insert #display :sout-all and select all boxes.
    Available for download from server
    Plugins
    vlcplayer-enigma2-testimage_1.0_powerpc.ipk
    youtubeplayer-enigma2-testimage_1.0_powerpc.ipk
    enigma2-plugin-extensions-partnerbox_experimental-cvs20100104-r0_powerpc.ip
    k
    enigma2-plugin-extensions-pauli_0.4.7_powerpc.ipk
    epgimport_0.1-r0_all.ipk
    graphmultiepg_1_powerpc.ipk
    enigma2-plugin-extensions-mediaplayer_2.8git20100325-r0_powerpc.ipk
    nrkplayer_0.1-r0_powerpc.ipk
    svtplayer_0.1-r0_powerpc.ipk
    enigma2-plugin-extensions-myspaceviewer_1.01_all.ipk
    enigma2-plugin-extensions-musicvideos_0.1_all.ipk
    enigma2-plugin-extensions-filebrowser_1.0_powerpc.ipk
    barryallen.v4.6.56_1_powerpc.ipk
    tuxtxt_0.1-r0_powerpc.ipk
    cccaminfo-v1.3_svn-2736-r0_powerpc.ipk
    permanentclock_2_powerpc.ipk
    mediacenter.v0.92_1_powerpc.ipk
    dreamexplorer.v1.5_1_powerpc.ipk
    epg2cf-enigma2-testimage_1.0_powerpc.ipk
    epg2usb-enigma2-testimage_1.0_powerpc.ipk
    enigma2-plugin-extensions-skintransp_0.4.0-r0_powerpc.ipk
    googlemaps_2.6cvs20090407-r0_powerpc.ipk
    mosaic_2.6cvs20090407-r0_powerpc.ipk
    webcamviewer-pictureviewer_2.6cvs20090407-r0_powerpc.ipk
    enigma2-plugin-extensions-autotimer_2.6cvs20090407-r0_powerpc.ipk
    enigma2-plugin-extensions-emailclient_2.6cvs20090407-r0_powerpc.ipk
    enigma2-plugin-extensions-epgsearch_2.6cvs20090407-r0_powerpc.ipk
    enigma2-plugin-extensions-orf_1.0_all.ipk
    enigma2-plugin-extensions-zdfmediathek_svn-3029-r0_all.ipk
    enigma2-plugin-extensions-fritzcall_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-httpproxy_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-logomanager_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-mediadownloader_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-passwordchanger_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-simplerss_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-startuptostandby_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-trafficinfo_2.6cvs20090820-r0_powerpc.ipk
    enigma2-plugin-extensions-webinterface_experimental-cvs20091103-r0_powerpc.
    ipk
    Skins
    infinity-ppc_1_powerpc.ipk
    lt6-hd-mod_1_powerpc.ipk
    brushedalu-mod_1.0_skin_powerpc.ipk
    brushedalu-mod-hdd_1.0_skin_powerpc.ipk
    dmm-mod_1.0_skin_powerpc.ipk
    dmm-mod-hdd_1.0_skin_powerpc.ipk
    Nemesis.GlassLine.II-mod-tunhj1_1_powerpc.ipk
    x2line_1.0_skin_powerpc.ipk
    lt-chromeline-cobolt-mod-tunhj1_0.1-r0_powerpc.ipk
    blueline-metall_1.0_skin_powerpc.ipk
    Software
    python-pyopenssl_0.6-r0_powerpc.ipk
    twisted-web_8.1.0-r0_powerpc.ipk
    python-crypto_1.9a6-r1_powerpc.ipk
    python-html_2.5.1-ml3_powerpc.ipk
    python-imaging_1.1.5-r1_powerpc.ipk
    python-shell_2.5.1-ml3_powerpc.ipk
    python-textutils_2.5.1-ml3_powerpc.ipk
    twisted_8.1.0-r0_powerpc.ipk
    twisted-web2_8.1.0-r1_powerpc.ipk
    zope-interface_3.3.0-r0_powerpc.ipk
    python-email_2.5.1-ml3_powerpc.ipk
    twisted-mail_8.1.0-r0_powerpc.ipk
    python-zlib_2.5.1-ml3_powerpc.ipk
    python-compression_2.5.1-ml4_powerpc.ipk
    Many thanks to all the friends of TestImage for encouragement and advice, in particular to erdbeere for the new bootlogo, jjfuertes for helping with plugin partnerbox, nikos62 for the skin Infinity-mod and the PeterPan Team for various suggestions !
    Regards, pcd.
    mai multe imagini Enigma2 le gasesti aici: http://www.sat-universe.com/forumdisplay.php?f=18
    arhanghelxxl
    Sal'[email protected]
    Minune mare -da chiar cum ai reusit sa pui E2 pe un aparat care nu o poate primi adicatelea nici n-o poti instala .Totusi fa ceva poze la aparatul minune iar daca merge zi-mi si mie ca mai am pe undeva un dm7000 si poate pun si eu E3 cand iese!
    Dec 2007
    nowhere
    Iara s-a intamplat.Se sar la cei care au 6 posturi.De ce nu mergeti si voi la link-ul dat .Scrie clar DM7020 enigma 2 , test.Scuze de offtopic.
    Quote Originally Posted by neovox View Post
    Uite aici o multime de image E pentru dm7020. http://www.i-have-a-dreambox.com/wbb2/database.php
    Mentionez se misca lent cu E, pune GP E1. Sau schimba dreamboxu cu unul HD.
    Jun 2010
    Multumesc pentru sfaturi. Cred ca problema nu este de la imagineaE1 sau E2, ca se misca mai lent sau nu, pur si simplu dupa o perioada nu mai primeste comenzi din telecomanda si trebuie restartat. Alta este buba cu siguranta.
    Ceva asemanator patesc si eu pe un DM 7000, dar perioada de timp la care se blocheaza este mult mai mare. Oare este problema de soft sau de hardware?
    Daca este de hardware atunci ii rog pe cei care cunosc un specialist sa-mi spuna si mie.
    Ai grijă să obţii ce ţi doreşti n viaţă sau vei fi obligat să te mulţumeşti cu ce primeşti.
    1). DM7020S e stabil daca il folosesti pentru Enigma 1(am pus si eu-experimental o imagine E2, dar nu se preteaza);
    2). Pune in FLASH memory Firmware (Release from 12.09.2005)
    3). Utilizeaza un stick USB pentru instalarea in Multiboot, cu FlashWizard PRO v6.3, a viitoarelor imagini pe care le vei folosi in mod curent. De Firmware nu mai ai nevoie sa te atingi;
    4). Un simplu search pe forum iti face o imagine clara despre ce imagini testate se folosesc pe DM7020S;
    Pt. mine, in ultima vreme, cele mai bune si stabile imagini pt. DM7020S, sunt:
    -EDG-Nemesis-4.2_DM7020.nfi
    -gemini-470-dm7020-200912021653.nfi
    -pli-jade3-dm7020-20090627-6494.nfi
    Ramine la latitudinea ta sa testezi CVS-uri sau imagini de E2, dar nu vei avea garantata stabilitatea si calitatea imaginii
    P.S. Pina una alta, daca te documentezi, DM a ramas cel mai stabil si fiabil si cel mai bun produs Dream Multimedia pt receptia transmisiilor SD
    Jun 2010
    Multumesc pentru sfat. Am facut si asa cum spui tu si acelasi rezultat.
    Am incarcat cu dreamup imaginea din 2005 in flash, iar in pe CF si usb am pus un gemeni 470. La fel face. Problema ma depaseste!
    Cred ca trebuie "consultat" de un "doctor"!
    __________________
    Cum pot scapa de eroarea aceea care apare atunci cand incerc sa instalez pe CF cu Flash wizzard gemini 4.70 pe un dream 7020?
    Multumesc!
    Scoate CF-ul si foloseste doar stick USB-ul.
    Instalarea Firmware sa o faci doar cu, cablu null-modem(9-9)
    Mai multe "siretlicuri" de instalare vezi in HowTo de aici , fiind similare cu cele de la DM500
    Jun 2010
    am facut ceea ce spui tu atat cu usb-ul singur cat si CF acum cateva zile.Acum am doar usb-ul si tot asa face.
    Quote Originally Posted by first_zipper View Post
    S-W RO
    Am si eu pe un DM7020 ultimul GP si nu am avut pb de blocaj. E posibil sa apara probleme daca aveti multe linii C si/sau multe pluginuri instalate ( verificati in /var cum stati cu spatiul).
    Succes !
    Aug 2003
    Karlsruhe- Arad
    Eu unul Nu sunt prieten cu GP_ul din aceasta cauza nici nu am avut stiut ca este ceva de genul E2 ptr DM 7020 - Sorry
    pe 7020_ul meu am in flash scvs-image-dm7020-20081209201343- de pe IHAD
    si pe CF card - am Nabilo Darkstar
    USB_ul l-am lasat liber ptr. ca am avut nevoie de el ptr. Smargo
    Si pot spune ca merge foarte stabil
    OK- nu am Picons - zeci de Skinuri- etc. doar ce este necesar ptr. a viziona un Program TV in liniste
