    May 2005
    Default HELP - NBA+ -STRONG 4355ev WITH CONCORD
    Please help me,
    How can I get chanel NBA+ with receiver STRONG 4355 evolution with CONCORD patch.
    I can not see there BISS key editor.
    Thank You
    Zare
    look for DCW edit or something, if not there, then maybe it is not patched for BISS. or try shooting for turksat, tune in to NBA. who knows maybe the BISS keys are already embedded and hidden from the menu. failing that, change your STB.
    look for DCW edit or something, if not there, then maybe it is not patched for BISS. or try shooting for turksat, tune in to NBA. who knows maybe the BISS keys are already embedded and hidden from the menu. failing that, change your "STB".
    Sir,
    What is STB?
    May 2005
    Default thanks
    thank you but
    It was patched for BISS I had NBA+. probably is hidden from the editor.
    Is there any other way to patch - I had patched with latest concord patch but it has no proper key for NBA+
    Zare
    Default STB
    TIFFANY, STB MEANS SATTELITE BOX.
  1. patch Strong 4155 Concord full (105)
    By xxx007 in forum SD Receivers
    Last Post: 12th May 2006, 16:55
  2. Patch nou Concord pentru Strong 4155-4355?
    By dragonlexus in forum SD Receivers
    Last Post: 21st November 2005, 13:29
  3. Cumpar Strong 4355 Evo cu patch Concord
    By orange in forum Shop
    Last Post: 27th June 2005, 15:50
  4. Strong 4125 Concord Viasat Europe
    By alin1209 in forum SD Receivers
    Last Post: 21st April 2005, 13:42
