Results 1 to 3 of 3
    Jul 2010
    Default Technical question
    Hello everyone,
    i want to buy a new sattelite receiver but i am somehow confused, so if any one can give me some suggestion i will appreciate that, my question are:
    1- does a HD receiver still able to receive normal digital channel that are not HD ?
    2- from the following models which one is the best in the following criteria
    - channel reception and demodulation systems and if it can be upgraded in the ...ure
    - the cripting system that it can decode or emulate.
    here are the receptors that i am thinking of:
    1-Optibox HD 2CICX
    2-Opticum HD X550
    3-Optibox Panthera
    4-Opticum HD 9600
    5-Opticum HD TS 9600
    6-Optibox Koala
    7-Optibox Alligator
    for my side i think the only differance between the optibox panthera and alligator is that the alligator has a terestrial tunner if am right.
    this don't mean that am not open for other suggestion type.
    thanks.
    Jul 2010
    Wink About the receivers optibox
    As well as I know Optibox Alligator, Optibox Panthera and Optibox Koala differ little from each other but Alligator is a bit more functional, that's all. So you may choose one according to your intuition or perhaps according to which of these nice animals you like most)
    Jul 2010
    Default hd9600
    Hi, i guess you can choose hd9600, for it's got the most manageable interface and could be easily connected to any digital device. hd also has a usb-port. so you can try to get keys for decriptors. as for me i do not approve any kind of software piracy
