Results 1 to 3 of 3
    Junior, da' cresc Mentor
    online
    Default Cum join doua .avi-uri cu audio bitrate diferit?
    Salut.
    Am un film impartit in 10 .avi-uri. As vrea sa le fac un join pt ca apoi sa le transform in format DVD. Problema este ca am 3 tipuri de bitrate la audio: cateva sunt encodate la 147 Kbps, 48000 Hz in MPEG Layer3, altele la 149 kbps, 48000Hz iar altele la 152 kpbs 48000 Hz. Encodarea video e Xvid la toate, acelasi framerate ( 23.976 ) si aceeasi rezolutie. Am incercat in fel si chip sa le aduc pe toate la 147 kpbs, 48000 Hz, insa fara succes. Undeva cred ca fac o gresala. Am incercat VirtualDub - nu merge. Am incercat GordianKnot - nu merge. Am incercat AVI Joiner - nu merge. Am incercat Easy Video joiner - cu asta am reusit sa le fac join, insa avi-ul rezultat nu este playabil ( cred ca indecsii sunt dati peste cap ).
    Daca aveti o solutie, va rog tare mult s-o postati.
    Mersi!
    xyboox. Din Transilvania.
    May 2004
    Romania - OLTENIA
    DM500S Offset Al 1.4m LNB Invacom 0.3dB + 1 X DIGI TV + 2 x DOLCE
    May 2004
    Romania - OLTENIA
    Aici a postat un tip care are aceiasi problema ca si tine.
    http://www.videohelp.com/forum/viewtopic.php?t=276944
    SUCCES
  1. Cel mai prost bitrate
    By clader in forum RDI - Satelit
    Last Post: 21st August 2006, 04:29
  2. bitrate provideri
    By gabi in forum DTH & Cable-Romania
    Last Post: 15th January 2006, 17:44
  3. Bitrate dbox2
    By costello_ in forum DREAMBOX
    Last Post: 6th November 2005, 14:59
  4. APROPO DE BITRATE si REZOLUTII
    By newsat in forum DTH & Cable-Romania
    Last Post: 31st October 2005, 19:58
  5. Replies: 10
    Last Post: 15th February 2005, 01:53
