Results 1 to 15 of 18
    Italy/Cluj
    Post MAXEVO ORCHID High Definition Satellite and Terrestrial receiver
    MAXEVO ORCHID
    Product information
    - High Definition Combo : 1080p,1080i, 720p, 576p
    - HDMI digital connection
    - 2 SmartCard readers and 2 Common Interface to access scrambled channels
    - Program recording and playing through USB 2.0 port
    - Ethernet and RS232 ports
    - Multiple connectivity: Scart, stereo RCA L/R Audio, YPbPr video, optical and coaxial SPDIF output
    - DiSEqC 1.2, USALS and Unicable compatible
    Technical specifications
    General
    - Satelite (DVB-S2)
    - Frequency range 950 ~ 2150 MHz
    - LNB supply 13.5 / 18 V DC, 500 mA max.
    - DiSEqC Version 1.1, 1.2, USALS & UNiCABLE
    - Demodulation QPSK, 8PSK
    - Input symbol rate 10 ~ 45 MS/s
    - Input connector F, Female
    - Terrestrial (DVB-T)
    - Frequency range VHF: 174 ~ 230 MHz
    UHF: 470 ~ 860 MHz
    - Channel bandwidth VHF: 7 MHz
    UHF: 8 MHz
    - FEC 1/2, 2/3, 3/4, 5/6, 7/8
    - Guard Interval 1/32, 1/16, 1/8, 1/4
    - Input connector IEC 169-2, Female
    - Profile level MPEG-4 AVC/H.264
    - Aspect ratio 4:3, 16:9, Letter Box
    - Video resolution 1080p, 1080i, 720p, 576p
    - Digital Audio Dolby AC3, Dolby Digital +
    Connections
    - Audio & Video HDMI
    YPbPr
    Scart
    Audio&Video L/R
    Optical and coaxial SPDIF digital output
    S-Video
    - Data Ethernet port 10/100
    2 x USB 2.0
    RS-232C 9-Pin D-Sub tipo Macho / Female type
    - Conditional access:2 Smart Card reader
    Power supply
    Input voltage AC 100 ~ 250 V, 50/60 Hz
    Physical specifications
    Dimensions 335 x 100 x 285 mm
    Net weight 1.95 kg
    La prima incercare cu cccam merge fara intrrupere pe canalele Sky DH ,schimb rapid de programe ,merge in share mediaset premium pe digitale terestre.O sa revin si cu imagini
    Jul 2009
    In the dropout zone
    Poate ar fi utile niste reviewuri complete, avizate (si, desigur) neutre.
    Sí seńor, efectos especiales!
    Feb 2010
    Cluj/Satu Mare
    Da cred ca niste informati ar fi bine venite
    Italy/Cluj
    Post
    menu Orchid S2T
    http://www.youtube.com/watch?v=24-K510JWSs
    Procedura cambio firmware
    http://img571.imageshack.us/i/howtoa...heemuands.pdf/
    Soft cam cccam:
    with this file server configurations can be created on your PC and send via USB to MAXEVO S2T.
    Next synthase:
    C: 192.168.1.2 12000 User Pass
    C: = server connects to CCcam
    192.168.1.2 = IP or server name
    12000 = server port
    user = username
    pass = password
    newcamd
    H: 192.168.1.2 12000 user3 pass3 01 02 03 04 05 06 07 08 09 10 11 12 13 14
    K: xxxx -> replace encryption numbers
    NOTE:
    You can also create a line of server "encrypted". Server connections are stored encrypted in the receiver:
    Using the same synthase as above, but the line starts with P:
    P: 192.168.1.2 12000 User Pass
    WARNING:
    The C: - and P:-line should be introduced early in the softcam.key file. And the file should be named as Softcam.key
    Jun 2010
    Default heloo
    greetings.
    can discourage the use as a server? . to use as a server. regards
    Jun 2010
    Default orchid - bad USB entries or bad soft?
    hello,
    i record new soft from 10/05/2010 to Orchid, but receiver cant see any HDD
    i try both of USB but usb readers dont work
    Has got anybody this problem?
    thanx for answer
    Italy/Cluj
    Post
    Se poate folosi si ca server.
    Cine are probleme cu usb/HDD se rezolva cu revenirea la impostatiunile originale de fabrica din Meniu si incarcare de firmware din nou.Dupa incercarile facute de mine depinde si de memori usb/stik ce se foloseste pt ca nu toate le accepta
    For problems with USB / HDD resolve to return to original factory firmware menu and load the new firmware.
    Jun 2010
    i try factory reset but without success
    receiver still dont see usb
    Quote Originally Posted by stelrob View Post
    Italy/Cluj
    Post
    Here is update fille for Maxevo --USB--
    http://rapidshare.com/files/395452952/_update.rar.html
    And here is fille for Maxevo use HyperTerminal Windows
    http://rapidshare.com/files/39545391..._3.11.rar.html
    Jun 2010
    thanx a lot
    i try it tonight and result write here
    Jun 2010
    i try it but no succes
    i use the file with which i connect with Illusion thorought HYPErterminal
    protocom - YMODEM
    orchid - dont reaction
    can you send me contact to you on PM?
    mail, ICQ, skype
    thanx
    Italy/Cluj
    Post
    Quote Originally Posted by maxelko View Post
    protocom - YMODEM
    mail, ICQ, skype
    thanx
    ok pm my contact
    Jun 2010
    my procedure:
    i use null modem cable rs232/ 2-3, 3-2, 5-5/
    1, off MAXEVO from electric site
    2, open hyperterminal with file maxevo.htm from you
    3, i select SEND file - main..... and i select protocol YMODEM
    4, CLICK ON SEND
    5, turn maxevo on, in electic site or with button on bottom / 0/1 /
    6, push button in the front side
    7, maxevo start - load
    8, and and nothing will happen, hyperterminal write No response
    please say me where I make a mistake?
    thanx
    Italy/Cluj
    Post
    my procedure:
    4, CLICK ON SEND
    thanx
    Wait turn online skype and do everything
    Jun 2010
    i do everything but problem is the some No response
