Results 1 to 3 of 3
    Default i need help for matrix loader
    hellofriends, i need your help. coz i have a matrix cam but i can not load the software to my receiver. please help on how to load
    Bud2
    You need a Fun Card 7 and a programmer which will handle this card, ie Infinity USB. Just programe the card, then go to a FTA channel on your receiver, select Conditional Access in the menu of your receiver, insert Funcard you should then have the option to programe Cam, follow on screen instructions. At some point it will say to re-boot your receiver, turn it off remove Funcard switch receiver on and wait approx 5 mins for Cam to initilise, when this is done you should able to view channels.
    a cas2/cas3 would be best for your needs. anyhow, if you already got the funcard7 then you go with the procedure as mentioned above, go to menu of your receiver, select Common Interface, select your MR. go to setup, then click on update firmware, insert your pre-programmed funcard, then hit download. don't interrupt, reboot and initialise afterwards. take note though that this process is not guaranteed to work on the first try, you may even have to load different MR software versions. just keep on trying.
  1. loader
    By najeem in forum RDI - English
    Last Post: 9th July 2006, 23:02
  2. Loader for Matrix Reloaded CAM?
    Last Post: 13th March 2006, 04:22
  3. help loader loader 2.08
    By RADUSOVA in forum SD Receivers
    Last Post: 1st November 2005, 11:43
  4. Need Loader
    By Marwat233 in forum RDI - English
    Last Post: 14th September 2005, 05:43
  5. I HAVE NEED LOADER TECHNOSAT T 888 LOADER
    By fawad dws in forum RDI - English
    Last Post: 31st July 2005, 08:01
