    MALAYSIA
    Default help... polarization problem!
    I recently acquired a used astro box for measat1 to replace my maxplus receiver. problem was when i hooked the same sat cable onto the astro box, it couldn't pick any signal cos the polarization was default set to "vertical" whereas my maxplus box was set to "horizontal" which I can get 93% signal with maxplus setting.
    I'm really confused here as lyngsat stated the relevant TPs as "V". Now why is this happening? Is there a way i can manually tweak the settings on the original astro box to change polarization to "Horizontal"? or do i really need to climb up the roof to adjust the LNB itself? help pls.. thanks.
    yes you can manually rotate the lnb enter frequency ect and rotate lnb for max signal the receiver should be able to do this through the menus H V and L circular R circular
    B4 Qatar, now Pinas (# 9)
    Well if you have another dish, you can keep it in vertical and the other in horizontal facing the same direction. In that case you don’t need to turn it over and over again.
    M A B U H A Y !
    MALAYSIA
    apparently, it works perfectly if i set receiver settings to "H". i wld prefer to work frm the receiver side before having to climb up the roof.
    but as i'm not familiar with the original astro decoder, i have no idea how to change the polarity settings in the software. I've tried change the settings manually... but it kept asking for a PIN. Anybody know the PIN?It's a Philips DSX6170/68A.
    thanks
  1. VERY SERIOUS PROBLEM.
    Last Post: 27th July 2006, 02:16
  2. Problem about hot 6.9
    By spot1bay in forum RDI - English
    Last Post: 15th March 2006, 13:25
  3. Log in problem
    Last Post: 18th November 2005, 17:12
  4. problem with ECM
    By raphex in forum Placi DVB
    Last Post: 15th November 2005, 13:51
  5. @ problem
    By msalman in forum RDI - English
    Last Post: 30th July 2005, 08:13
