Page 1 of 4 123 ... LastLast
Results 1 to 15 of 53
    Sep 2002
    Default DVB-T : USB-Stick mania
    TECHNAXX DVB S4 - USB 2.0 DVB-T Stick
    Technical Specifications:
    • Worldwide DVB-T TV watching
    • Recording of Video / Audio
    • Customize channel management
    • Time shifting and scheduled recording
    • EPG (Electronic Programming Guide)
    • Capturing of images in multipe formats
    • Supports HDTV resolution up to 1920x1200 and
    16:9/16:10/4:3 widescreen
    • Supports MPEG2/MPEG4, H.264
    TV Tuner:
    • TV: 48.25 ~ 863.25 MHz, Fully DVB-T compliant
    • Channel Bandwidth: 6MHz, 7MHz, 8MHz, COFDM,
    16-QAM, 64-QAM
    High Definition TV (HDTV):
    • 480i/480p/720p/1080i
    Hardware l/O:
    • 75O TV/FM antenna input
    Operating Systems:
    • Windows XP/Vista (32 or 64 bit)
    System Requirements:
    • Intel Pentium IV 2.4GHz or equivalent AMD CPU
    • Graphics with 16MB DDR and Mirosoft DirectX 9.0c
    support (for Vista 128MB DDR recommended)
    • DirectSound compatible sound card
    • 512MB RAM (for Vista 768MB recommended)
    • Windows XP / Vista (32 or 64 bit)
    • Available USB 2.0 connector
    • 10GB free space on Hard Disk
    • CD/DVD ROM drive
    SHALOM
    Aug 2008
    misto jucaria
    Cat ai dat pe el? oricum stie doar DVB-T era fain daca stia si DVB-C.
    Sep 2002
    Quote Originally Posted by stailus View Post
    Hehe, la 15.6 euro vrei cam multe Prima mea jucarie HD
    SHALOM
    MuSic & So mucH MoRe! Expert
    Aug 2003
    Svishtov
    Thumbs up I Mac?
    Bravo!
    Sunt curios dacă merge si pe MAC OS.
    Thanks!
    DVB-S:
    Offset Emme Esse (Alu.) 1.25
    Offset Emme Esse (Alu.) 1.15
    DVB-T:
    Sep 2002
    N-am MAC, dar daca vrei ti-l dau sa probezi.
    SHALOM
    Aug 2003
    Svishtov
    Default Multumesc.
    Când ai timp treci pe la mine.
    Te astept la un suc.
    DVB-S:
    DVB-T:
    Sep 2002
    Stai mooo, de-abia ieri l-am platit, e din Germania (am luat si o masina de facut paine). Probabil o sa ajunga in cateva zile. Te anunt.
    SHALOM
    Oct 2002
    Default nu exista tuner dvb-t HD de PC din punct de vedere hardware
    Desi poate este poate trivial ce spun pentru multi, nu ma pot abtine sa nu remarc pentru a N-a oara ca nu exista tuner DVB-T HD de PC (intern pe PCI sau extern pe USB) care sa posede hardware special pentru HD in afara de aplicatia soft cu care vine si care este aproape sigur mai proasta decit orice aplicatie freeware de client DVB.
    Specificatii de genul:
    • Supports HDTV resolution up to 1920x1200 and 16:9/16:10/4:3 widescreen
    fac parte din arsenalul de marketing, agresiv si gratuit in opinia mea care vine cu mai toate gadget-urile din ultimii ani.
    Sep 2002
    Si eu ma gindeam. dar la banii astia am zis ca n-o sa fie o teapa prea mare si o sa fie ok chiar daca merg doar SD-urile. Il astept
    SHALOM
    Sep 2007
    La ce pret au alea DVB-C, mai bine iti cumperi TV direct cu DVB-C decat sa bagi asa ceva pe PC.
    vasile e mai ieftin sa oferi decodare software. Plus ca majoritatea PC-urilor din ziua de azi se descurca cu H.264, asa ca n-ar trebui sa deranjeze prea tare.
    isr2002, iti merg HD-urile cu el, doar ca o sa iti manance si din procesor.
    Sep 2002
    Quote Originally Posted by MasterC View Post
    ..isr2002, iti merg HD-urile cu el, doar ca o sa iti manance si din procesor.
    Sa manance ca are de unde.
    Placa video de pe PC e asta: ASUS EN7600GS SILENT/ HTD 256 GEFORCE 7600GS, PCI EXPRESS, 256 MB DDR, 400/ 800MHz, 128BIT, TVO(HDTV), DVI, SILENT
    Partea tare e ca n-am monitor nici tv HD Mi-am cumparat potcoave acum trebuie si cal.
    SHALOM
    Eu am luat un terratec care stie de toate in materie de terestru si cablu ... o fost vreo 80 euroi deci mai scump clar, dar sa stii ca face.
    Sep 2002
    N-am avut niciodata contract de cablu.
    SHALOM
    Dec 2007
    Bucuresti 6 - Drumu' Taberei
    Quote Originally Posted by isr2002 View Post
    Placa video e buna, insa pacat ca nu are accelerare hardware completa pentru H.264 (PureVideo HD http://www.nvidia.com/page/purevideo_HD.html ). Are numai pentru MPEG2 (PureVideo http://www.nvidia.com/page/purevideo.html ). Chipset-urile nVidia sunt compatibile cu PureVideo HD, incepand cu seria 8xxx (fara 8800).
    De restul decodarii si procesarii se va ocupa procesorul principal (CPU).
    Quote Originally Posted by the the
    Bravo!
    Thanks!
    Daca e compatibil cu MAC sau cu Linux se poate afla, in mod sigur, numai daca stii chip-urile din care e compus, pentru ca e posibil sa existe drivere, dar sa nu fie incluse in setul standard ( sau sa aiba aceeasi configuratie ca un alt stick, dar alt ID si deci, sa necesite o modificare minora in drivere).
