Results 1 to 9 of 9
Thread: Offset LNB
    Hikkaduwa / Sri Lanka
    Default Offset LNB
    Who knows the beamwidth or viewing angle from offset lnb's?
    I always find 90°.
    For prime focus lnb's we can change it with scalar ring (F/D ratio),but for offset lnb's it is not possible.
    Default Re: Offset LNB
    Quote Originally Posted by Kaefi
    I always find 90°.
    What is your problem with your LNBF?
    bombastik
    beamwidth and look angle are specs of antenna dish not lnb as far as i know, the larger the dish the narower the beamwidth more gain, look angle depends on the geometry of the dish, with offset type usually 27 degrees compare to prime focus type.
    I did not ask about the beamwidth of an antenna,which can be easily calculated.
    I asked about the feedhorn beamwidth or the viewing angle from offset lnb's or the F/D ratio.
    For a prime focus lnb you can change the viewing angle or F/D ratio with the scalar ring.
    But with offset lnb's it is not possible,it is fixed.
    My suggestion: F/D = 0,5 and viewing angle 90°
    Why worry on something you can not change!
    canine consultant Expert
    Firstly are you talking about C-band off-set or Ku off-set.
    C-band off-set will require a scalar ring as a normal prime focus dish does , except the rings on the scalar ring are cut at an angle to fit in with the dish, and focal length can be adjusted in the normal way.
    With Ku, the angle of the LNB in relation to the face angle of the dish is dependant on the dish size, as each dish size has a differant angle. The easest way to get the angle and settings for a off-set LNB arm, is to hold the LNB in front of the dish and move it rounfd slowly until you find a signal, then measure the distance from the dish, and make up a set of arms to suit.
    regards from OZ bassett
    I have a prime focus dish with a diameter of 610cm, focal length 239cm and the feedhorn beamwidth is 130,6 degrees.
    Now there is the question if my invacom offset lnb (0,3 db) will "see" the whole dish or only a part of it.
    Anyhow I have also a prime focus lnb from invacom (0,3db) with feedhorn and adjustable scalarring - but with the offset lnb I get a stronger signal.
    As far as I know , the dish could be offset and not LNB.
    Offset LNBF has a wider F/D ratio (.5 to .7) specification which makes it receive more signal that prime focus lnb. But if the prime focus LNB is located on the proper location, it will receive same amount of signal as the Offset LNBF.
  1. Offset 0.90 + Digi 300
    By robex in forum DTH & Cable-Romania
    Last Post: 2nd September 2006, 06:37
  2. Vand offset 1.85m
    By cleo in forum Shop
    Last Post: 20th July 2006, 11:12
  3. Service offset
    By mariust5 in forum RDI - Satelit
    Last Post: 8th March 2006, 09:12
  4. LNB offset
    By bebelus in forum RDI - Satelit
    Last Post: 26th December 2005, 11:39
  5. Offset de 1,10m
    By Nokia in forum RDI - Satelit
    Last Post: 20th September 2005, 12:37
