Results 1 to 3 of 3
    P R I M E Mentor
    Timişoara
    Default probleme sunet ALTDVB
    Salut! Vad ca sunteti mai avansati ca mine in ceea ce priveste programul Altdvb.De aceea imi permit sa va cer ajutorul.Am instalat programul(am versiunea cea veche ,nu update-ul) asa cum scrie in fisierul txt al programului,dar am 3 probleme.
    1.NU AM SUNET PE NICI UN CANAL
    2.DUPA CE SCHIMB MAI MULTE CANALE IMAGINEA APARE DUBLA.ADICA PE IMAGINEA PRINCIPALA APARE O DUNGA NEAGRA UNDEVA IN DREAPTA SI IN DREAPTA EI O ALTA PORTIUNE DIN IMAGINEA PRINCIPALA.CAM STUFOASA DESCRIEREA MEA DAR NU SUNT SPECIALIST IN DOMENIU.
    3.EPG-ul nu merge(not implemented)Asa imi apare.
    Revin la rugamintea de a ma ajuta cu vreun sfat.
    Multumesc anticipat.
    Apr 2004
    arround the world
    Pai sunet nu ai ptr ca trebuie sa bagi niste codecuri, iar imaginea este dubla ptr ca probabil mergi pe codecul standard si pe unele canale face figuri, deci si aici trebuie sa bagi codecul cyberlink, care merge perfect. Asa ca iti recomand ace mega codecs pack 5.93 sau mai sus.
    P R I M E Mentor
    Timişoara
    Default raspuns
    Pachetul de care zici are 41 Mb.Si internetul e prin dial-up.Daca as sti care e codecul ala nenorocit care da sunet in progr asta l-as cauta pe net.Cyberlink incercat->nu merge.oricum,mersi de sfat.
  1. AltDVB - Sunet doar cu Power DVD pornit
    By johst in forum Placi DVB
    Last Post: 4th February 2006, 00:19
  2. probleme sunet dm500
    By smarius in forum DREAMBOX
    Last Post: 29th December 2005, 16:18
  3. PROBLEME LA SUNET CU DBOX2
    By mh80cos in forum DREAMBOX
    Last Post: 20th September 2005, 00:32
  4. probleme sunet pe STRONG 6355
    By mihaip in forum SD Receivers
    Last Post: 11th March 2005, 00:30
  5. problema altdvb sunet
    By dio in forum Placi DVB
    Last Post: 28th July 2004, 19:36
