Results 1 to 9 of 9
    Italy/Cluj
    Post Digital Satellite Receiver Atlas, 2 Smatcard readers Enternet
    Product information
    • 2 SmartCard reader embedded
    • Display
    • 4000 channels
    • 8 Favourite lists
    • OSD: Spanish, English, German, French, Slovak, Portuguese,
    Czech, Romanian, Polish, Arabic…
    • 1 LNB input
    • 1 SCART (CVBS, RGB, YCbCr)
    • S-VHS
    • Audio STEREO - RCA L/R
    • RS232C port for software upgrades
    • Ethernet connection
    • DiSEqC 1.0, 1.1, 1.2 support
    • DVB and MPEG2 compatible
    • EPG (Electronic Program Guide)
    • Automatic channel search
    • GoTo-X protocol embedded
    • Go-To City function
    • Clock, Sleeper, Freeze
    • S/PDIF digital audio output, AC3 bit stream retransmission (Dolby
    Digital 5.1)
    Hi everybody, the new version of KYNG Software is available in the downloads section it's version A2.19.
    • Added :(All Models) Viaccess 2.6 Emu implementation. The supported providers are Bis TV,ART and JSC.
    Ilusion.Clarke-Tech 2100/2500/3100/5100,Ilusion,Vantage,AbIpBox,Unixbox,Doulabs importator ,cas3 ,etc....
    Feb 2010
    Cluj/Satu Mare
    Post
    Pe asta la incercat cineva in share?Vad ca are 2 locuri pt card.Stie cineva ceva?
    Italy/Cluj
    Thumbs up Tools & Editors For Illusion-Kyng Download Center
    http://rapidshare.com/files/35329888..._V1.0.zip.html
    Italy/Cluj
    Quote Originally Posted by goguhat View Post
    Aici ai imagini din meniu cu tot ceea ce poate face si te asigur ca face cam tot ce ar trebui sa faca un decoder bun si la bani putini
    http://rapidshare.com/files/352298746/Atals_E.rar.html
    Italy/Cluj
    Thumbs up New software version A2.21.
    • Fixed :(Atlas-E/M3S2/M2S Plus) The bug related to showtime provider whe using sharing.
    • Fixed :(Atlas-E/M3S2/M2S Plus) Sky Italy NDS cards support locally and through CCcam.
    • Fixed :(Atlas-E/M3S2/M2S Plus) Simple EPG correction which makes it much faster.
    Italy/Cluj
    Thumbs up New software version A2.22 sky Fix
    • Fixed :(All Models) Various audio and audio languages related bugs.
    • Added :(Atlas-E/M3S2)2 new options in the "Ethernet" menu, realetd to TNTSAT and Sky Italy Providers hadling
    Italy/Cluj
    Thumbs up New Version A2.23!!!
    Version A2.23!
    • Fixed :(All Models) Improved compatibility with dongles such as "Timer V" and "MoreBox". This functionality has been thoroughly tested.
    • Added : (All Models) Sky Italy NDS cards support locally and through CCcam.
    • Added :(Atlas-E/M3S2/M2S Plus)Increased the maximum number of supported providers when using NewCamD.
    • Added : (All Models) The possibility to update Omnia cards on all models, not only the Atlas.
    • Fixed : (All Models) All DiSEqC related problems including switches and motors.
    May 2009
    Default sal
    Salut ,spune-mi te rog cum merge atlasul pentru digi in sharing,sau se merge si cu emu pe n3?
    Italy/Cluj
    in share merge struna......daca pui ultimul firmware la serverul ce are implementat in el mai vezi multe ....pe 13 s°yit si spoturele Al Jazeera Sports de la 1 la 8 ....francezi ...etc
