    Default 2 metabox , 2 dish help
    i have 2 metaboxs and 1 ku band for dreamtv and 1 c band dish . what do i need to make both ku band and c band work on both metaboxs, i tried using the loop out but assoon as i change a channel the other metabox freezes ... both my lnb's are single output.. if anyone can help thanks .
    Atif_Khan
    dear ,
    u should use a DISEQC 2.0 for connecting two more dishes, and use a high quality wire, which ll not break ur signal ,
    Atif Khan
    u should get a twin-out for the ku lnb since you cannot view channels on both receivers if the polarity are different for such channels (V & H). that would be your best and cheapest option. using the loop out will work only if you are viewing channels on the same polarity. of you can buy a multiswitch disecq which would cost you more. twin/dual out lnb is my suggestion.
    thanks both of you .. boknoy dual out ku band lnb , single out c band is enough ? .. and do i still need a diseqc switch ? i have a 0/22 switch .. a lil more help on what else do i need please. and how to attach everything together , ty guys .
    single out cband lnb would be enough, you can connect it to a powerpass splitter/divider, then on to your disecq switches (you need two since you have two receivers.
  1. i can data transfer Metabox 10 to e-Metabox ??
    By heinlynn in forum RDI - English
    Last Post: 18th September 2006, 15:34
  2. DISH ACTIVE - on Dish TV
    By mj786 in forum RDI - English
    Last Post: 30th August 2006, 23:29
  3. Dish Tv with 35cm dish
    By Imran in forum RDI - English
    Last Post: 11th December 2005, 05:42
  4. Dish Tv satellite dish price
    By KAZIM ALI in forum RDI - English
    Last Post: 11th August 2005, 06:41
  5. Please I need help for Metabox
    By yani in forum RDI - English
    Last Post: 29th July 2005, 21:28
