    Lahore
    Default How to focus offset dish ?
    It is a great challenge to focus 5/1-2 footi dish on Hotbird.Plz help me.
    What is the duna tv frequency for analogue receiver?
    Fte Max 100S
    Humax IRCI-5400z
    Apr 2004
    Germany
    Default Re: How to focus offset dish ?
    Dear Masood,
    Duna Tv has following freq. 10815 H and is broadcasted in analogue PAL .....
    if u possess a low threshold (LT) Receiver then u should able to get this channel ...... not clearly maybe but atleast u should be able to recognize the channel ..... U need a receiver with a very sensitive tuner ...... well focussing is indeed the most dificult part of our hobby and u know it too good that beside long hard work there is no alternative means no trick (atleast i know non) which u could apply to get the desired result in quicktime
    good luck and let us know if u were succesful
    it helps if you can have a satellite finder meter, as this device is quite sensitive to the db strenght you receive on your dish (it takes some time for your receiver to reflect the signal quality sometimes).
    Lahore
    Thanks for replies ,I have focussed after a struggle of three nights
    I had to drop at forward side almost whole dish
    It seems LNB is getting rays from earth
    Any how it is having a good result.
    Now my location is Lahore
    Fte Max 100S
    Humax IRCI-5400z
    duna tv aalogue so there will be no signal quality only strength
  1. Replies: 4
    Last Post: 27th August 2011, 07:27
  2. Comparatie - 1,85 Offset cu 1,8 Prime focus
    By WoobyZ in forum RDI - Satelit
    Last Post: 8th December 2006, 17:18
  3. 6ft Offset Dish Stand
    By Shakin in forum RDI - English
    Last Post: 19th July 2006, 21:04
  4. LNB holder for Prime Focus dish
    By charly20 in forum Shop
    Last Post: 24th February 2006, 23:39
  5. OFFSET DISH MULTI-FEED SYSTEM
    By nirolf in forum RDI - Satelit
    Last Post: 22nd June 2005, 20:46
