Results 1 to 3 of 3
    Default Triple Dragon help
    I have a new triple dragon reciever. It has the latest 8MB full image on it and beerman v10 added. It now gets only the free preview channels. I think it needs the Nagra 2 keys updated. Can someone point me to a how to or advice how I can do this. I found softcam.keys file for it but it is a registry type file and I'm lost on what tool to use to upload it or if this is even the correct file. I will owe someone a big favor for some advice. Thanks
    You must update your keys use a ftp program connect to your triple find there var folder and copy paste my triple dragon key files but dont forget not all the emu plugins can open nagra2 for example on one image only radegast can open d+ on other image only evo and mgcamd not gbox and newcamd you can find all the triple emu images here
    http://www.ump2002.net/index.php download section
    Mach 1 , I appreciate the help with your reply. I have been trying to connect to TD with flash ftp using the IP # the router has given it but keep getting connection refused. I set the network settings in TD menu to built in ethernet with DHCA as I was told to do but no luck so far. Its been an all day fight to get this going to no avail so far. I know I'm close if I could just FTP it. Thanks
  1. Triple dragon
    By elrumano in forum DREAMBOX
    Last Post: 8th December 2010, 01:12
  2. DVB subtitle pt Triple Dragon
    By onyx in forum DREAMBOX
    Last Post: 10th August 2006, 17:37
  3. TRIPLE DRAGON DBS-3000CNCIE
    By orange in forum SD Receivers
    Last Post: 25th September 2005, 17:52
  4. Triple Dragon
    By mustang in forum RDI - Satelit
    Last Post: 6th September 2005, 00:24
  5. VAND TRIPLE DRAGON
    By BIHOREANUL in forum Shop
    Last Post: 14th June 2005, 14:18
