Results 1 to 15 of 21
    DISH CITY Teacher
    India
    Smile Beetel S 25 MPEG 4 SD satellite receiver General Review
    MPEG 4 Part 10 / H.264,
    Profile Level 3 ,
    Standard MPEG-2 ISO/IEC 13818,
    Resolution 720 x 576 PAL & 720 x 480 NTSC,
    A/V Out RCA/Coaxial,
    Serial port RS-232C 9 Pin.
    DiSEqc:1.0 & 1.2
    Teletext & EPG
    1. Operating function entirely different from normal MPEG 2 FTA receiver (this is my first MP 4 SD FTA receiver so no comparison).Hidden functions irritates to operate the receiver.
    2. Automatic Installation Function: I din’t find blind scan option, in automatic installation receiver searches already loaded transponder frequency. So manual frequency loading required.
    3. To edit Transponder, satellite, scan satellite & DiSEqC follow colour coding in the RCU.
    4. Manual Scan: All, Netwok Search & select scrambling services (conax, ...... etc)
    5. Auto DiSEqc : As in manual it should detect DiSEqC automatically when auto selection selected.(I tried with 5 DiSEqC it didn’t detected display shows no DiSEqC connected. I mixed both C & KU band ). DiSEqC selection Tone Brust, Poart A-D & Up 16 selection are there.
    6. Multi Picture Selection: choose between 4 to 16 windows. (Only one picture running)
    7. Select channels according to satellite, scrambling services, service provider etc
    I paid 3300 INR.I din’t find blind scan option so not satisfied.
    Megahertzpark
    Africa-Kenya-Nbi
    Can see your disappointments,
    I have tried and is using Strong 4669X,
    some outstanding features;
    Mpeg 4 compliant,
    Advanced Blindscan
    Pvr ready through usb,
    Data upgrade through usb
    Has rs 232 port for comp.
    component video output
    Jul 2009
    India
    Is there any Viewing Card slot in Beetel S25 or in S21 and does it support Viaccess
    DISH CITY Teacher
    India
    Quote Originally Posted by Balen View Post
    No CAM in S 25
    Megahertzpark
    Jul 2009
    India
    Pliz post some Mpeg 4 receiver brands (which dont have PVR) which have Card Slot at low cost. Like Innovia IDS 3088ca (mpeg 2) have two card slots
    Dec 2007
    Kerala
    Try to buy MPEG4 DBS 2 Stb's
    Hope now local brand stb's with low price available in the market.
    Dec 2007
    INDIA
    Cool Price
    Mpeg 4 compliant,
    Advanced Blindscan
    How much for it. I wish to buy one. Is it available in India ?
    DISH CITY Teacher
    India
    Angry
    Dont buy beetel S25 receiver. It is nothing but a junk
    Megahertzpark
    Dec 2007
    INDIA
    Cool Thanks
    Quote Originally Posted by kachak View Post
    Thanks friend, I am trying for alternatives.
    Dec 2007
    INDIA
    Default Mpeg-4 stb
    Still waiting for reply from experts. Info about any other good MPEG-4 STB also welcomed.
    Chennai, India
    Quote Originally Posted by anishpsla View Post
    There are now many unbranded MPEG4 receivers available in the market Names I forgot but I think other than names most of them are same thing Cheapest thing for us at present is D2h as they are unlocked DVBS2 and costs 1600 with few months subscribition and we will also get Dish, LNB and cables. But lacks blind scan.
    Apr 2006
    Pakistan, Multan
    Its better to go for DVB-S2.
    Dream Box 800HD, Neotion 3000, SS2,
    12 Feet Motorized Dish 128 E to 3 E
    Jan 2009
    Limuru, Kenya
    Quote Originally Posted by rizwan77 View Post
    I second Rizwan, It would be more advice able to go for a Dvb-s2 as that is where satellite technology has migrated too.
    Beware so some Dvb-s2 receivers as the miss some of the Audio and Video codecs thus the tend to be cheaper like Strong 4900 and 4910 Hd which are currently incapable of decoding some Audio AAC codec. When asked the software engineer at Strong Technologies in Dubai they replied "Although the SRT4900/10 is AAC compliant, It needs licence."
    I would advice to check on such issues when sourcing for a Dvb-s2 receiver. Go for a receiver that supports 3rd Party applications like Dreambox 500hd, Dreambox 800Hd, AzBox Premium Plus HD and others.
    Also forum support is a important factor to consider when choosing a Dvb-s2 receive.. The more website offering info, tutorial, firmware and update on a particular receiver the better for your learning and entertainment experience.
    Dec 2007
    INDIA
    Cool Dm500 hd
    How much I need to spend for a DM500 HD ? Is it a good one for basic HD needs ?
    Jul 2010
    Unhappy About the purchase
    Great purchase!
    Why didn't you check all the functions at the place? Was there a guarantee card or something on this product?
    One should be careful when buying something like that.
