Results 1 to 15 of 15
    Apr 2004
    Exclamation CCcam+Hub USB+Smargo
    Am un server UBUNTU cu un hub usb si 3 smargo.
    In CCcam.cfg am :
    CAMKEY: /dev/ttyUSB0 00 00 00 00 00 00 00 00
    CAMDATA: /dev/ttyUSB0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    TRY ALL CHIDS : /dev/ttyUSB0
    SERIAL READER : /dev/ttyUSB0 smartreader+
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB0 6000000
    CAMKEY: /dev/ttyUSB1 00 00 00 00 00 00 00 00
    CAMDATA: /dev/ttyUSB1 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    TRY ALL CHIDS : /dev/ttyUSB1
    PHOENIX READER PATH : /dev/ttyUSB1 smartreader+
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB1 3759000
    CAMKEY: /dev/ttyUSB2 00 00 00 00 00 00 00 00
    CAMDATA: /dev/ttyUSB2 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
    TRY ALL CHIDS : /dev/ttyUSB2
    SERIAL READER : /dev/ttyUSB2 smartreader+
    SMARTCARD CLOCK FREQUENCY: /dev/ttyUSB2 3579000
    Folosesc 3 carduri:
    1-....../ 1-viacces/ 1-connax.Merge perfect!
    Dar,
    - Daca pun 2 cartele ...... si una de viacces le vad pe toate 3
    - Daca pun 2 cartele connax si un viacces le vad pe toate 3
    - Daca pun 2 cartele viacces(clok 3759000) NU VAD DECAT UNA DINTRE ELE!
    Ce setare trebuie sa fac in CCcam.cfg sa vad ambele cartele de viacces?
    Multumesc anticipat!
    Antena 1.9 Al cu actuator.
    T90 -> 8 LNB Twin
    Restu',sincer, nu conteaza !
    http://img23.imageshack.us/img23/1909/myserverx.jpg
    OSCAM-ul va distruge SHARING-ul
    Cam complicat pe la tine prin config, cel putin la cartelele de Viaccess.
    Eu am asa, pentru fiecare reader in parte, Frequenta este fixa, nu auto:
    SERIAL READER : /dev/ttyUSB0 smartreader+ #N3/Sky/8,00 Mhz
    SERIAL READER : /dev/ttyUSB1 smartreader+ #Via/Akta/4.8 Mhz
    SERIAL READER : /dev/ttyUSB2 smartreader+ #Via/Free X/Dorcel/4,0 Mhz
    SERIAL READER : /dev/ttyUSB3 smartreader+ #Via/Hrt/4.0 Mhz
    SMARTCARD SID ASSIGN : /dev/ttyUSB0 ......
    SMARTCARD SID ASSIGN : /dev/ttyUSB1 ......
    SMARTCARD SID ASSIGN : /dev/ttyUSB2 ......
    SMARTCARD SID ASSIGN : /dev/ttyUSB3 ......
    Merge
    TM
    Default v
    iar pt un smargo via
    http://www.cesarex.com/product_info.php?products_id=591
    care ar fi cfg ,eu ampus asa dar nu vede nici un card
    SERIAL READER : /dev/usb/tts/1 smartreader+
    SMARTCARD CLOCK FREQUENCY: /dev/usb/tts/1 4860002
    Aug 2003
    Karlsruhe- Arad
    @ Bumbu
    si eu i am avut scr in alt Board tot asta
    doar stii tu ca si eu am 3 Smargouri pe Hub- din care una este Conax si una este Viacces
    si la mine merge
    TM
    Quote Originally Posted by BOMBER View Post
    @ Bumbu
    si la mine merge
    de care zic eu e un smargo via fara leduri si nu e la fel ca un smartreader+
    care il am im tty1 si mege perfect
    Aha, deci Smargo totusi nu e Smargo, adica cu led si fara led.
    Poti sa pui cumva un Link de pe un Site cu acest Smargo fara led, sa vad si eu cum arata Sincer sa fiu, inca nu am auzit de un Smargo fara led, dar bag de seama ca exista, de aceea sunt interesat, si cam la ce pret ar fi acest reader. Mai am un loc la PC pentru un SMARGO, de aceea sunt interesat.
    Numai bine
    TM
    Default s
    smargo via in debian cu dmesg il vede asa
    [ 4723.231415] usb 1-2: Product: FT232R USB UART
    [ 4723.231415] usb 1-2: Manufacturer: FTDI
    [ 4723.231415] usb 1-2: SerialNumber: VIACARD1
    Aug 2003
    Karlsruhe- Arad
    @bradu
    chiar ca m-ai facut si pe mine curios de acest '' Smargo '' fara LED
    cum a scris si Bumbu- ceva link - poza - ceva - cred ca sunt mai multi curios de asa ceva
    la mine este asa in config.- si setat pe Fix NU pe Auto
    ############# SMARGO READER ###################
    SERIAL READER : /dev/usb/tts/0 smartreader+
    SERIAL READER : /dev/usb/tts/2 smartreader+
    SERIAL READER : /dev/usb/tts/3 smartreader+
    ce Nu pot intelege totusi- din care cauza ai pus atitea zeroouri
    asa se pune - dupa cite stiu eu la o gamma card ptr. ......
    rog Moderatorii sa ne scuze- ca deviem de la tread
    TM
    Default w
    de aici am cumparato ca are un pret mai mic dar in poza e smartgo normal ...celalant care lau trimis e la fel dar nu are gauri pt led si nu se poate programa cu smargo.exe nu il vede....am si un smartgo reader+ care am mai zis merge perfect......am incercat cred ca toate conbinatiile pe pc cu debian si dm 8000 .cind il pun in dm apare pe ecran usb recunoscut dar nu pot sal fac sa citeasca cardurile care le am seca ,nd,via,nagra .....acolo zice ca are suport pt card T0 T1 ...care sint nu stiu
    Germany
    Pentru ce este acest: SID ASSIGN?
    Apr 2004
    Thumbs up Multumiri
    Multumesc pt. sfaturi!
    Am rezolvat cu 'coment' la 'CLOCK'.
    T90 -> 8 LNB Twin
    TM
    Default smargo via
    @bradu
    da cam greu cu pozele......am trimis mail la cei care au vindut usb smargo via si mi-a venit raspuns ca se poate configura cu VIACARD COMF CONFIG un prg care nu-l gasesc nicari....aici am pus un tutorial cfg cu poza smargo via
    http://rapidshare.com/files/31331751...rd_manuale.pdf
    Aug 2003
    Karlsruhe- Arad
    @bradu
    am luat fisierul
    Ok arata ca Smargo- dar se programeaza total diferit -
    ai avut dreptate
    Nu am mai vazut asa ceva
    Apr 2004
    Exclamation Hub usb pe Dream 800?
    Se poate pune un hub usb pe dream 800?
    Daca da, cum trebuie configurat in cccam.cfg?
    Disat
    T90 -> 8 LNB Twin
    Default 2xSmargo + Dm 800 + CCcam
    Salutare
    Am pe un dm 800 un hub cu patru porturi si doua smargo pe acest hub. Pe celalat port usb nativ al DM 800 am un stick wireless. Problema mea este ca pe cele doua smargo nu pot sa initializez decat carduri de Dolce NDS, daca pun un card de Max sau TVR ambele viaccess, cardurile nu pot fi initializate de CCcam si le reseteaza tot timpul fara a le recunoaste idiferent de frecventa de lucru a cardurilor ( am incercat 3.57 si 6.00 Mhz ) .
    Aveti idee de la ce poate sa vina aceasta anomalie de nu initializeaza cardurile de viaccess.
    Eu banuiesc ca si cauza modulul ftdi_sio pt smargo ( folosesc Nabilo Black Hole Hyperspace ) pentru ca imi da niste mesaje ciudate in consola la comanda dmesg
    [email protected]:~# dmesg
    D430 - 3FF3D438
    ofo requeuing : rcv_next 3FF3D3E9 seq 3FF3D3E9 - 3FF3D430
    ofo requeuing : rcv_next 3FF3D430 seq 3FF3D430 - 3FF3D438
    out of order segment: rcv_next 83F39429 seq 83F39462 - 83F3946A
    out of order segment: rcv_next 83F39429 seq 83F3946A - 83F394B8
    ofo requeuing : rcv_next 83F39462 seq 83F39462 - 83F3946A
    ofo requeuing : rcv_next 83F3946A seq 83F3946A - 83F394B8
    out of order segment: rcv_next 84C33171 seq 84C331AA - 84C331E9
    ofo requeuing : rcv_next 84C331AA seq 84C331AA - 84C331E9
    out of order segment: rcv_next 34D41494 seq 34D4149C - 34D414CD
    out of order segment: rcv_next 34D41494 seq 34D414CD - 34D414DD
    ofo requeuing : rcv_next 34D4149C seq 34D4149C - 34D414CD
    ofo requeuing : rcv_next 34D414CD seq 34D414CD - 34D414DD
    out of order segment: rcv_next 3FF3E2E9 seq 3FF3E891 - 3FF3EE39
    out of order segment: rcv_next 3FF3E2E9 seq 3FF3EE39 - 3FF3F3E1
    out of order segment: rcv_next 3FF3E2E9 seq 3FF3F3E1 - 3FF3F989
    out of order segment: rcv_next 3FF3E2E9 seq 3FF3FF31 - 3FF3FFBA
    ofo requeuing : rcv_next 3FF3E891 seq 3FF3E891 - 3FF3EE39
    ofo requeuing : rcv_next 3FF3EE39 seq 3FF3EE39 - 3FF3F3E1
    ofo requeuing : rcv_next 3FF3F3E1 seq 3FF3F3E1 - 3FF3F989
    out of order segment: rcv_next 3FF3F989 seq 3FF3FFBA - 3FF40011
    out of order segment: rcv_next 72170F50 seq 721714F8 - 72171933
    ofo requeuing : rcv_next 56FE4425 seq 56FE4425 - 56FE4464
    ofo requeuing : rcv_next 56FE4464 seq 56FE4464 - 56FE446C
    out of order segment: rcv_next DE23002 seq DE2300A - DE23043
    out of order segment: rcv_next DE23002 seq DE23043 - DE2304B
    out of order segment: rcv_next DE23002 seq DE2304B - DE230FB
    out of order segment: rcv_next DE23002 seq DE230FB - DE23103
    out of order segment: rcv_next DE23002 seq DE23103 - DE23151
    out of order segment: rcv_next DE23002 seq DE23151 - DE23159
    ofo requeuing : rcv_next DE2300A seq DE2300A - DE23043
    ofo requeuing : rcv_next DE23043 seq DE23043 - DE2304B
    ofo requeuing : rcv_next DE2304B seq DE2304B - DE230FB
    ofo requeuing : rcv_next DE230FB seq DE230FB - DE23103
    ofo requeuing : rcv_next DE23103 seq DE23103 - DE23151
    ofo requeuing : rcv_next DE23151 seq DE23151 - DE23159
    out of order segment: rcv_next DE2351D seq DE23556 - DE2355E
    ofo requeuing : rcv_next 721714F8 seq 721714F8 - 72171933
    out of order segment: rcv_next DE2351D seq DE2391F - DE23927
    out of order segment: rcv_next DE2351D seq DE23927 - DE2396E
    out of order segment: rcv_next 15B151E4 seq 15B15784 - 15B15B7C
    ofo requeuing : rcv_next DE23556 seq DE23556 - DE2355E
    out of order segment: rcv_next DE2355E seq DE2396E - DE23AAA
    ofo requeuing : rcv_next 15B15784 seq 15B15784 - 15B15B7C
    ofo requeuing : rcv_next DE2391F seq DE2391F - DE23927
    ofo requeuing : rcv_next DE23927 seq DE23927 - DE2396E
    ofo requeuing : rcv_next DE2396E seq DE2396E - DE23AAA
    out of order segment: rcv_next 53228774 seq 532287AC - 5322889A
    ofo requeuing : rcv_next 532287AC seq 532287AC - 5322889A
    out of order segment: rcv_next 842196E2 seq 84219C8A - 8421A232
    out of order segment: rcv_next 842196E2 seq 8421A7DA - 8421AD82
    ofo requeuing : rcv_next 84219C8A seq 84219C8A - 8421A232
    out of order segment: rcv_next 26B69438 seq 26B69479 - 26B69481
    out of order segment: rcv_next 26B69438 seq 26B69481 - 26B694BF
    ofo packet was already received
    ofo requeuing : rcv_next 26B69481 seq 26B69481 - 26B694BF
    ofo requeuing : rcv_next 8421A7DA seq 8421A7DA - 8421AD82
    out of order segment: rcv_next 8421C422 seq 8421C9CA - 8421CF72
    out of order segment: rcv_next 8421C422 seq 8421CF72 - 8421D51A
    out of order segment: rcv_next FA816F4E seq FA8174EE - FA817A8E
    out of order segment: rcv_next FA816F4E seq FA817A8E - FA81802E
    out of order segment: rcv_next FA816F4E seq FA81802E - FA8185CE
    out of order segment: rcv_next FA9CC649 seq FA9CCBE9 - FA9CD189
    out of order segment: rcv_next FA9CC649 seq FA9CD189 - FA9CD729
    out of order segment: rcv_next FA9CC649 seq FA9CD729 - FA9CDCC9
    out of order segment: rcv_next FA9CC649 seq FA9CDCC9 - FA9CE269
    out of order segment: rcv_next FA9CC649 seq FA9CE269 - FA9CE319
    ofo requeuing : rcv_next FA9CCBE9 seq FA9CCBE9 - FA9CD189
    ofo requeuing : rcv_next FA9CD189 seq FA9CD189 - FA9CD729
    ofo requeuing : rcv_next FA9CD729 seq FA9CD729 - FA9CDCC9
    ofo requeuing : rcv_next FA9CDCC9 seq FA9CDCC9 - FA9CE269
    ofo requeuing : rcv_next FA9CE269 seq FA9CE269 - FA9CE319
    partial packet: rcv_next B9387152 seq B93870AD - B9387153
    out of order segment: rcv_next E4E7FD53 seq E4E802B7 - E4E8081B
    out of order segment: rcv_next E4E7FD53 seq E4E8081B - E4E80D7F
    out of order segment: rcv_next E4E7FD53 seq E4E80D7F - E4E812E3
    out of order segment: rcv_next E4E7FD53 seq E4E812E3 - E4E81847
    out of order segment: rcv_next E4E7FD53 seq E4E81847 - E4E81DAB
    ofo requeuing : rcv_next E4E802B7 seq E4E802B7 - E4E8081B
    ofo requeuing : rcv_next E4E8081B seq E4E8081B - E4E80D7F
    ofo requeuing : rcv_next E4E80D7F seq E4E80D7F - E4E812E3
    ofo requeuing : rcv_next E4E812E3 seq E4E812E3 - E4E81847
    ofo requeuing : rcv_next E4E81847 seq E4E81847 - E4E81DAB
    out of order segment: rcv_next 424A07C7 seq 424A0D67 - 424A1307
    out of order segment: rcv_next 424A07C7 seq 424A1307 - 424A18A7
    out of order segment: rcv_next 424A07C7 seq 424A18A7 - 424A1E47
    out of order segment: rcv_next 424A07C7 seq 424A1E47 - 424A23E7
    out of order segment: rcv_next 424A07C7 seq 424A23E7 - 424A2413
    ofo requeuing : rcv_next 424A0D67 seq 424A0D67 - 424A1307
    ofo requeuing : rcv_next 424A1307 seq 424A1307 - 424A18A7
    ofo requeuing : rcv_next 424A18A7 seq 424A18A7 - 424A1E47
    ofo requeuing : rcv_next 424A1E47 seq 424A1E47 - 424A23E7
    ofo requeuing : rcv_next 424A23E7 seq 424A23E7 - 424A2413
    out of order segment: rcv_next 14D61109 seq 14D613B3 - 14D613BB
    out of order segment: rcv_next 14D61109 seq 14D613BB - 14D6148B
    ofo requeuing : rcv_next 14D613B3 seq 14D613B3 - 14D613BB
    ofo requeuing : rcv_next 14D613BB seq 14D613BB - 14D6148B
    out of order segment: rcv_next DA06090E seq DA060922 - DA060EC2
    out of order segment: rcv_next DA06090E seq DA060EC2 - DA061462
    out of order segment: rcv_next DA06090E seq DA061462 - DA061A02
    ofo requeuing : rcv_next DA060922 seq DA060922 - DA060EC2
    ofo requeuing : rcv_next DA060EC2 seq DA060EC2 - DA061462
    ofo requeuing : rcv_next DA061462 seq DA061462 - DA061A02
    out of order segment: rcv_next D930D286 seq D930D28A - D930D802
    out of order segment: rcv_next D930D286 seq D930D802 - D930DD7A
    out of order segment: rcv_next D930D286 seq D930DD7A - D930E2F2
    ofo requeuing : rcv_next D930D28A seq D930D28A - D930D802
    ofo requeuing : rcv_next D930D802 seq D930D802 - D930DD7A
    ofo requeuing : rcv_next D930DD7A seq D930DD7A - D930E2F2
    out of order segment: rcv_next 5EF0C090 seq 5EF0C638 - 5EF0CBE0
    out of order segment: rcv_next 5EF0C090 seq 5EF0CBE0 - 5EF0D188
    out of order segment: rcv_next 5EF0C090 seq 5EF0D188 - 5EF0D2C4
    out of order segment: rcv_next 5EF0C090 seq 5EF0D2C4 - 5EF0D86C
    out of order segment: rcv_next 5EF0C090 seq 5EF0D86C - 5EF0DE14
    out of order segment: rcv_next 5EF0C090 seq 5EF0DE14 - 5EF0E3BC
    ofo requeuing : rcv_next 5EF0C638 seq 5EF0C638 - 5EF0CBE0
    ofo requeuing : rcv_next 5EF0CBE0 seq 5EF0CBE0 - 5EF0D188
    ofo requeuing : rcv_next 5EF0D188 seq 5EF0D188 - 5EF0D2C4
    ofo requeuing : rcv_next 5EF0D2C4 seq 5EF0D2C4 - 5EF0D86C
    ofo requeuing : rcv_next 5EF0D86C seq 5EF0D86C - 5EF0DE14
    ofo requeuing : rcv_next 5EF0DE14 seq 5EF0DE14 - 5EF0E3BC
    out of order segment: rcv_next B1E17222 seq B1E177C2 - B1E177C4
    out of order segment: rcv_next B1E17222 seq B1E177C4 - B1E17D64
    out of order segment: rcv_next B1E17222 seq B1E17D64 - B1E18304
    out of order segment: rcv_next B1E17222 seq B1E18304 - B1E188A4
    ofo requeuing : rcv_next B1E177C2 seq B1E177C2 - B1E177C4
    ofo requeuing : rcv_next B1E177C4 seq B1E177C4 - B1E17D64
    ofo requeuing : rcv_next B1E17D64 seq B1E17D64 - B1E18304
    ofo requeuing : rcv_next B1E18304 seq B1E18304 - B1E188A4
    out of order segment: rcv_next 72173E1C seq 721743C4 - 7217496C
    Alte idei daca aveti, multumesc
