Results 1 to 2 of 2
    Default NEED HELP FROM RDI M8TS.
    RDI HEROES, PLEASE HELP ME TO FIND SOLUTION ON MY HUMAX 5400. THE PROBLEM IS WHEN I'M WATCHING FROM ARABSAT AND I CHANGE THE CHANNEL TO NILESAT ITS GIVING A BAD SIGNAL, THEN THE CHANNEL WILL APPEAR AFTER FEW MINUTES. I TOOK ANOTHER RECIEVER TO CHECK MY SATTELITE ANTENA SYSTEM AND ITS WORKING GOOD.I CHECK THE DISEQC SETTING AND ITS CORRECT.I UPDATE SOFTWARE HOPING THAT IT IS THE PROBLEM, BUT GIVING ME THE SAME RESULT.THANKS IN ADVANCE.
    Default Re: NEED HELP FROM RDI M8TS.
    Quote Originally Posted by snowite
    poor quality disecq switches will do this most of the time. try changing to something like Nasa disecq switches and you will see the difference. sometimes enabling the 22khz tone helps too.
