Results 1 to 3 of 3
    Sep 2009
    Unhappy Help Me !!!!!!!!
    Hi Friends
    I was using DISH TV in Dubai in my previous flat. Since i have shifted to a new tower in Dubai, i have a problem with the viewing of Dish tv.
    This new building does not allow me to put up my existing outdoor dish in the roof-top. Unfortunately i do not have a balcony tooo.
    ( Very unfortunate situation)
    Will the Indoor Dish Antenna work for receiving this DISH TV
    If so please do give me your expert advices on this !
    I just need this DISH Tv badly to be fixed......
    Please help !
    Best Regards
    Prakash
    unless you plan to sit that dish in you living room, with windows always open..........
    Africa-Kenya-Nbi
    Most apartments do not allow extra installations on their roofs, once they have a central system. But if you are more than 5 demanding the same they will consider loosing you, then 10 can have 1 dish..
    If the dish size is 90cm or below you can make a bracket fastened to your window grills and extended to the outside by about 3ft away from your wall and you have TataSky, lots of lack if it is towards the back of building - subject to satellite position.
    Identify the window and the angle for you sat, will give you a design if ku. If C Band 6ft then forget.
