Results 1 to 2 of 2
    Default techecnosat t-888 help
    technosat t-888 cable connection and upgrade process
    May 2004
    Lahore Pakistan
    UPGRADING PROCEDURE OF T888
    T-888 FTA
    Procedure to upgrade the Patch Software and to activate the emulation
    How to download the Software:
    Initially run the “StbV2” loader and connect the COM port. Upgrade software by pressing “F8”
    option, select the “software.cus” file and reset the DSR for upgrading.
    Method to activate the emulation:
    The DSR has to be loaded with emulation software for the scrambled channels to open. After
    upgrading, activate emulation by –
    1. Press “EXIT” button & “6108” through RCU (Remote Control Unit), activate patch.
    2. Then go to Menu  Parental Lock  Input Password  “0000”.
    3. Pay Channel Lock Status has to be “OFF” for the Scrambled Channels to work.
    Method to change the key codes:
    To view the Code Menu, go to Menu  Information  Code Edit. To update codes press “EXIT &
    8088” through RCU (Remote Control Unit).
    Multi-picture Option:
    Press “Blue” button, Multi PIG with 9 pictures made available.T-888 FTA
    CABLE CONNECTIONS
    2-----------------2
    3-----------------3
    5-----------------5
